Man I want one of these so badly...I'll never afford one!
I agree that the blurb is a bit OTT, but the functions are great IMO.
So I have also wondered about adding similar features to a VCA comp.
The Elysia is a discrete VCA, feed-forwards with a sweepable tilit filter at the output. I think the G-SSL is mostly feedback - and after much thought I'm leaning to the Pico as it's also feedforward, so might be the ideal platform to modify?
The coolest features to me are the G.R limit control, the filter and the anti-log mode.
[quote author="Emperor-TK"]BTW, it should be pretty easy to add a negative ratio feature to the GSSL. My first build had that "feature" before I was aware of the 2150 to 2180 conversions.
-Chris[/quote]
I want to spend some time to figure out how to add something similar. Personally have been thinking about a discrete audio path, THAT VCA comp for while...with tilt filter at the output or switched into the SC - which the Elyisa can't do.
Anyone reckon it would be possible to add anti-log, negative ratios to the Pico or GSSL? It must be possible to add a limit function to the D.C sidechain feed.
The manual has plenty of nice AP plots to help.
-T
