Flatpicker
META-Power Supplies
« on: October 05, 2004, 10:23:32 PM »
----------------------Power Supplies---------------------------
This is a META-thread, which helps you to keep track of the posts relevant to Power Supplies. The first post will contain links to all relevant threads.
Everyone is welcome and even encouraged to submit links.
I make every attempt to keep this META up to date. However, I don?t always catch everything, so please post links to anything you think should be here. I will add them to the existing ones in the first post and Jacob will periodically clean all other post from this thread. All suggestions and questions are welcome as well.
Thanks.
LAB LINKS:
Tube power supply info?
http://www.groupdiy.com/index.php?topic=2620&sid=ec63e78a163efd1a192a5828f359d455
+24V and +48V from one supply
http://www.groupdiy.com/index.php?topic=2564
Need a 24V AC!!!! wallwart adaptor. where to find ??
http://www.groupdiy.com/index.php?topic=2551
[EDIT] I have built a PSU - and now TOO much volts
http://www.groupdiy.com/index.php?topic=2308
wall wart power supply for ssl comp ??
http://www.groupdiy.com/index.php?topic=2646
green power supply
http://www.groupdiy.com/index.php?topic=2667
Question about G9 PSU
http://www.groupdiy.com/index.php?topic=2668
Power transformer output voltage ?
http://www.groupdiy.com/index.php?topic=2647
SSL 9k Power Supply...
http://www.groupdiy.com/index.php?topic=2619
Why 48V for phantom power? Who started this convention?
http://www.groupdiy.com/index.php?topic=2881&sid=af715a5965040492b43cd9b983f67509
Miniature Tube DI Idea
(Contains info for powering low filament/low plate voltage tube directly from phantom power source)
http://www.groupdiy.com/index.php?topic=1195&highlight=phantom+tube
[NEWBIE] Daft question, again, on Bench Power Supplies...
http://www.groupdiy.com/index.php?topic=2955
beefy multiple voltage psu
http://www.groupdiy.com/index.php?topic=3176&sid=77398daf881ace4a1651a35c992d7a78
How many VA do I need to power up my API 312 ?
http://www.groupdiy.com/index.php?topic=3178&sid=77398daf881ace4a1651a35c992d7a78
24V dc to 54V with only 2 components!
http://www.groupdiy.com/index.php?topic=3242
+5VDC Computer PSU question
http://www.groupdiy.com/index.php?topic=3318&sid=84a57b98449daa67fc56ad11e0ffb0d8
Embarrassing P/S question...
http://www.groupdiy.com/index.php?topic=3332&sid=78d0da87879b67a04fa2b30d2861c19f
Phantom power current requirements, AC vs. DC heater voltage
http://www.groupdiy.com/index.php?topic=3109&sid=78d0da87879b67a04fa2b30d2861c19f
Calrec PSU question
http://www.groupdiy.com/index.php?topic=3333&sid=78d0da87879b67a04fa2b30d2861c19f
phantom power noise
http://www.groupdiy.com/index.php?topic=3303&sid=78d0da87879b67a04fa2b30d2861c19f
300vdc plate, 19vdc heater psu
http://www.groupdiy.com/index.php?topic=1106
Switching vs. Linear power supply
http://www.groupdiy.com/index.php?topic=3710
Low power DC-DC converter for capsule charging?
http://www.groupdiy.com/index.php?topic=3804
Simple PSU question
http://www.groupdiy.com/index.php?topic=3908&sid=d0af9233a755ee3f3d34a1e8261561b6
Power supply Q's
http://www.groupdiy.com/index.php?topic=4349&sid=4cae5200911c8b2f6915d428bc0411e6
9K PSU transformer question/problem
http://www.groupdiy.com/index.php?topic=4312
Does the LM317 Have Output Short Circuit Protection
http://www.groupdiy.com/index.php?topic=4370&sid=a21de00986c565ef29dd159a97390b42
Power supply test load question
http://www.groupdiy.com/index.php?topic=4563&sid=d7d67dbb1a7672e86da0fad55ef383d9
Dumb power supply questions
http://www.groupdiy.com/index.php?topic=4924&sid=c70e932590f7e3bde3c341912221aebd
wall wart PSU replacement question/problem
http://www.groupdiy.com/index.php?topic=5065
Question about Iadj in LM317
http://www.groupdiy.com/index.php?topic=5114&sid=d4fb70a8048599747c1485c457ea8196
dual power supplies
http://www.groupdiy.com/index.php?topic=5196
What Happens when Zeners are paralleled?
http://www.groupdiy.com/index.php?topic=5084
Using 9 volt batteries for +/- 9v op-amp power
http://www.groupdiy.com/index.php?topic=4913
Barry Porter phantom powering schem
http://www.groupdiy.com/index.php?topic=5139
Another PSU problem
http://www.groupdiy.com/index.php?topic=5177&sid=8a0d10c3a0b5585c28d121d61682a2c8
Bauman PSU
http://www.groupdiy.com/index.php?topic=5282
Phantom question using available parts
http://www.groupdiy.com/index.php?topic=5325
48v power supply
http://www.groupdiy.com/index.php?topic=5591
newbie choosing toroid
http://www.groupdiy.com/index.php?topic=6266
Yet another 24V, 48V Power supply - comments please
http://www.groupdiy.com/index.php?topic=6372
+- power supply
http://www.groupdiy.com/index.php?topic=6469
Voltage Doublers
http://www.groupdiy.com/index.php?topic=6381
messing with voltage doublers on the simulator...
http://www.groupdiy.com/index.php?topic=6393
Designing a fixed B+ regulator
http://www.groupdiy.com/index.php?topic=6526
Power transformer questions...
http://www.groupdiy.com/index.php?topic=6596
Question for SSLtech +/- 18, 48v split supply
http://www.groupdiy.com/index.php?topic=6421
Low value caps in PSU - why electrolytic? why not film?
http://www.groupdiy.com/index.php?topic=7736
Negative Vreg questions..
http://www.groupdiy.com/index.php?topic=7769
will this work? 48/24 dc PSU
http://www.groupdiy.com/index.php?topic=7678
Bypassing PS smoothing electro caps
http://www.groupdiy.com/index.php?topic=8270
High Voltage Regulators
http://www.groupdiy.com/index.php?topic=8266
Torrid VA ratings, does too much juice hurt?
http://www.groupdiy.com/index.php?topic=8565
Need a +/- 15V PSU - MS20 Filter Clone...
http://www.groupdiy.com/index.php?topic=8382
AC power...
http://www.groupdiy.com/index.php?topic=10071
Placing a voltage doubler after a regulated power supply?
http://www.groupdiy.com/index.php?topic=10147
Can a Lin PSU be used for a device that uses Switching PSU?
http://www.groupdiy.com/index.php?topic=10030
PS Caps and Low Frequency Response
http://www.groupdiy.com/index.php?topic=10146
Using the JLM Audio PSU phantom 48V line as an additional Power Line (e.g. for relays)
http://www.groupdiy.com/index.php?topic=9609&highlight=jlm+48v
"linear"power supply "roundtable"
http://www.groupdiy.com/index.php?topic=10552
one transformer driving two bridges
http://www.groupdiy.com/index.php?topic=10875
Power Supply Issues
http://www.groupdiy.com/index.php?topic=10863
Two G9 power supply design questions
http://www.groupdiy.com/index.php?topic=10953
Interesting power supply design...
http://www.groupdiy.com/index.php?topic=11751
Universal power supply for your projects!
http://www.groupdiy.com/index.php?topic=954&sid=198c6e43290e09139a07d706d6dec620
Phantom pwr from a DC to DC converter?
http://www.groupdiy.com/index.php?topic=12807&sid=dd726099b41c821ceed4b8a766346a12
Power supply for preamps
http://www.groupdiy.com/index.php?topic=12861&sid=dd726099b41c821ceed4b8a766346a12
5A PSU schematic
http://www.groupdiy.com/index.php?topic=15057&sid=33b650e863ba0f93faacfc28e99ad6d4
need build psu +-16, +-48,+-12 15amp help please!!
http://www.groupdiy.com/index.php?topic=14892
What happens when you have two voltage regulators in series?
http://www.groupdiy.com/index.php?topic=14955
PM1000 Ideas - Good PM1000 PSU talk, especially on page 2 by Ulysses.
http://www.groupdiy.com/index.php?topic=15216&postdays=0&postorder=asc&start=15
voltage duobler for tube PSU
http://www.groupdiy.com/index.php?topic=15377
48v slow regulator question...
http://www.groupdiy.com/index.php?topic=14746
Power Supply - Ability to change the sound
http://www.groupdiy.com/index.php?topic=185544#185544
power supply will eat up rectifier tubes?
http://www.groupdiy.com/index.php?topic=16479
+48 volt phantom supply
http://www.groupdiy.com/index.php?topic=195392#195392
How to calculate the value of the mains fuse?
http://www.groupdiy.com/index.php?topic=16638
Haveing problem with PSU!! Please help??
http://www.groupdiy.com/index.php?topic=17420&sid=4bce0966f5b49902ef38dbb9117f4f80
A Phantom Power PSU
http://www.groupdiy.com/index.php?topic=17439&sid=4bce0966f5b49902ef38dbb9117f4f80
PSU too much current? (Explanation of OUT to ADJ resistor of LM317/337)
http://www.groupdiy.com/index.php?topic=18236
help with this PSU schemo and problem Edit: new photo added
http://www.groupdiy.com/index.php?topic=18230
DC-DC Converter Design
http://www.groupdiy.com/index.php?topic=19761
Troubleshooting the linear power supply
http://www.groupdiy.com/index.php?topic=19810
Regulators, practical differences
http://www.groupdiy.com/index.php?topic=19202
SMPS troubleshooting made easy
http://www.groupdiy.com/index.php?topic=19733
9 V To 48 V DC-DC Converter Design
http://www.groupdiy.com/index.php?topic=20108
For Noobies: Power Supply Basics Explained
http://www.groupdiy.com/index.php?topic=20252
Deriving a bipolar supply
http://www.groupdiy.com/index.php?topic=20868
_______________________________________________________
OTHER LINKS:
Fred Forssell's +/-24V/+48V preamp power supply for 115VAC line voltage.
http://www.forsselltech.com/gerbers/MikePrePS1.PDF
How to get +/-15V and +48V from a single 18VAC wall adapter.
http://www.rane.com/pdf/ms1bsch.pdf
Power Supplies - Lots Of Basic Design Info...
http://www.kpsec.freeuk.com/powersup.htm
Transformer VA calculations - MUST reading for volts, amperes, watts & such for different rectifier configurations!
http://www.atc-frost.com/products/design/va.htm
Regulator & Reference Stuff from Walt Jung
http://waltjung.org/Regs.html
Group DYI Power Supplies
http://web.archive.org/web/20050212160253/recording.org/users/kev/PS.htm
ESP Linear Power Supply Design
http://sound.westhost.com/power-supplies.htm
Voltage Multipliers
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/voldoub.html
Lots O' Links
http://www.epanorama.net/links/psu_linear.html
Power Supply Basics
gyraf
Re: META-Power Supplies
« Reply #1 on: February 19, 2017, 01:43:55 AM »
Plitron: Design notes on Power transformer Efficiencies - about sizing power supplies
https://www.plitron.com/news/technical-notes/
Jakob E.
Last post August 19, 2004, 04:43:04 PM
by NewYorkDave
Last post September 17, 2004, 07:11:06 PM
by CJ
Last post September 22, 2009, 05:39:56 AM
by SNG
Last post January 25, 2005, 08:50:48 AM
by Peter Simonsen
