Clearance size for buttons in panels?
intellijel
So I am in the process of designing a PCB that will have a bunch of tact switches on it. Each tact switch has a square cap that is 10mmx10mm and they have a geometric tolerance of +/-0.2mm. So if I am designing the openings for these on a panel design the squares have to be bigger than 10.2mmx10.2mm but what should the ideal size be? e.g. How much clearance should I design in? 0.1mm? 0.2mm? ??
thanks,
Danjel
