rodabod said:If ther diaphragm is getting sucked then either buy a new capsule (or spare from someone who swaps theirs), or you could try lowering the B+ voltage in the supply by swapping the zener diodes.
Gus said:Crash
If you are using it with voice are you using a pop filter? It could be dust on the capsule leaking the charge with moisture from breath if you are not using a pop screen if it is a 67/87 type capsule.
rodabod said:Try breathing heavily on the mic without blowing hard (to cause condensation) and see if this cause the same effect.
Or just use a pop filter and see if it stops happening!
Crash said:I have to get all up on it for it to finally cut out. I would guess this means a dust issue?
rodabod said:Crash said:I have to get all up on it for it to finally cut out. I would guess this means a dust issue?
That's natural for condensers, but gets worse with dust/dirt. Sucking onto the backplate is not, but that doesn't sound like your issue.
rodabod said:Crash, does it affect both sides equally?
Inspect by eye for dust around the edges. If it's an issue, then search here for guidance about using a small soft brush to remove particles. Josephson gave a good introductory guide.
I'd still also try it with a good pop filter though...
Gus said:I have microphones that had the same problem out of the box. I open the china tube microphones before I power them up to check the PCBs and I often remove the grill and check the capsule for dirt and other problems before the first power up.
Google K67 and K87 and CK12 look at the pictures. The neumann 87/67 type have a insulating no gold deposited area at the edge. That area is were dust and moisture can make a leakage path and discharge the charge on the capsule. Often using a dry artist brush and light touch you can remove the dirt/dust there.
Ptownkid said:Marik, which clip is which? I'm assuming ribbon1 is the modded one...
