jcharles00
i searched around, but couldn't find this info, if it exists on here, a link would be great.
[backstory]
so anyway, i dug out the green pres i stuffed years ago and decided to try and figure out why they didn't work back then. i no longer have access to a bench PSU, so i am trying to finish the one that a third party started making for me for the green project. the design was pretty similar to peters, but different in some ways.
the +15/-15V rails are done, but the phantom circuit is only as far as the voltage multiplier stuff.. so it's hanging with an unregulated 90V at it's end currently.
[/backstory]
in going through the test process, i noticed my voltages from the power supply are off a little. like +15.2/-14.67V. I'm using an 815 and 915 regulators, respectively.
my first question is, since these are fixed regulators, can i assume that the variance i'm seeing is just their standard tolerance?
second question, how to i remedy this? i could just throw a resistor on the positive rail to knock it down, but i don't know how to make up what i need on the negative rail. do i just order a bunch of replacement regulators and try them all until i get closer?
final question: to finish the 48V rail, i have all the parts except an adjustable 317 regulator. i do have a couple non-adjustable 317s that apparently yeild 37V. would this be acceptable here for testing sake?
thanks, and i apologize for the dumb questions.
[backstory]
[/backstory]
