Macbook pro owners , can anyone help ?
andre tchmil
land of chicon
I know, not exactly the right place here to ask, but ask a long time member ...; :oops:
My macbook pro refuses to charge the battery., still works with PS.
I pulled out the battery and measured on the pins where the battery is placed.
I have 3 X 3,45 V on 3 of the 5 pins. Can someone check this ?
I would like to know if this is correct/ sufficient, before I jump to the mac store and get a new battery.
thanks in advance.
I had the exact same problem... had to replace the battery. :mad: it's only like 120.00 dollars. the mac guy suggested only charging the battery when necessary instead of leaving it plugged in like I tend to do...
Get a new battery. Usually it's better when you charge it fully and use it FULLY (until the red battery sign in the OS) so it completes its full cycle every time - that tends to prolong battery life.
If it's under warranty you'll get the replacement for free =) Sometimes even if it's JUST gone out of warranty.
