JAYJAYBEE
Active member
Just a post to confirm how to ground my GSSL.
OK so the earth pins on the 2 inputs are linked together right.
and the same for the 2 outputs, but are these both then connected to the chassis.
also do i use metal pcb posts (stands) to connect the board to the chassis as 3 of theese are grounded right, and a nylon one for the one that isnt.
what do i do with the earth pin from my iec power inlet, do i just connect it to the chassis also.
I want to get this right as i think its the most important part safety wise, i dont want to die any time soon and worse blow my beloved GSSL.
Is there a wiring schematic anywhere on here i have tried searching but no luck.
cheers doods
cheers doods
