I'm considering building a few rack spaces of tube gear. If I size the power transformer big enough to power several tube heaters and have enough current for the B+ can I use just ONE power supply for several pieces of gear?
I'm also considering the same for the Solid State stuff. I'd like to have a +-15VDC; 24VDC; 48VDC supply. With the low voltage Solid State supply I've read that each channel should have it's own Voltage Regulator. Is there any problem with using a single Low Voltage Solid State and a single High Voltage supply for many units?
