ffarrell
Re: [BUILD] 1176 Rev F/G - new board, new transformer!
« Reply #440 on: May 01, 2017, 11:36:16 AM »
Hi all.
Where do you guys pull power from for the polit light on a dual 1176 ver. F?
Fvf
Hairball Audio
« Reply #441 on: May 01, 2017, 06:31:43 PM »
Hi all.
Fvf
Meter lamp?
Look through here:
http://www.hairballaudio.com/blog/resources/build-guides/wiring-your-compressor-
Bottom.
Hairball Audio, LLC
DIY Parts and Kits
https://hairballaudio.com
Top secret stuff and upcoming releases:
http://instagram.com/Hairballaudio
http://facebook.com/hairballaudio
ffarrell
« Reply #442 on: May 01, 2017, 06:43:59 PM »
The power on pilot light. But I think I would just pull off the 30 volt leg and resistor it down like the meter lamp.  Im using a 6.3 volt guitar amp bulb.
One other question on the 1176 F rev 1.2 board if I'm using the ic input and not the tranie should R5 be unpopulated?
Fvf
« Last Edit: May 01, 2017, 06:48:41 PM by ffarrell »
Hairball Audio
« Reply #443 on: May 01, 2017, 06:49:02 PM »
Fvf
Look like it should be left out.
Hairball Audio, LLC
DIY Parts and Kits
ffarrell
« Reply #444 on: May 01, 2017, 06:51:11 PM »
Thank you
Fvf
ffarrell
« Reply #445 on: May 11, 2017, 07:34:26 PM »
If the tolorance of the resistors on this build are 5% can I use a 261k 1% in place of the 270k on the release pot?
Fvf
Hairball Audio
« Reply #446 on: May 11, 2017, 07:36:28 PM »
Fvf
The original used 10%. You'll be just fine with that value.
Hairball Audio, LLC
DIY Parts and Kits
ffarrell
« Reply #447 on: May 11, 2017, 08:15:07 PM »
thanks
fvf
ffarrell
« Reply #448 on: May 19, 2017, 11:08:33 AM »
Ok, I want to finish this stereo 1176F  but a few more question please.
1.  Should I be using shielded cable from the stereo link PCB boards back to the output pots?
2.  Should I calibrate the unit before I add in the Stereo Link boards?
thanks
fvf
ffarrell
« Reply #449 on: May 23, 2017, 08:14:31 AM »
bump..
Hairball Audio
« Reply #450 on: May 23, 2017, 11:09:20 AM »
thanks
fvf
1. Yes.
2. Up to you. SHouldn't mater unless the link boards are built wired/wrong.
Mike
Hairball Audio, LLC
DIY Parts and Kits
Olegarich
« Reply #451 on: August 12, 2018, 09:07:50 AM »
Hey guys, I know this topic was noted posted in loing time, but still
I have problem with calibration. Actually it's the last step. Tracking adjustmen t.
I did everyt single step and all works well,
When Gain reduction is Off (Atack knob fully CCW) i read 10dbu on putput xlr
When gain reduction is on (Atack knob is CW) I read 0 dbu (0.77v)
My meter show me 1dbu drop when GR is turned on, and tracking adjustment trimpot is can't go any further. Trimpot is working for 100.
So basicly i wanted to ask is this can only be in the meter drive amp section? Cause i measure drop on xlr output but Meter not showing me this.
Hairball Audio
« Reply #452 on: August 14, 2018, 02:05:17 PM »
If the GR is happening, but you can't get the meter to match, you have an issue in the GR Meter Amp section.  Make sure you have a 2K pot in there and make sure your IC is inserted correctly or not dead.  Could also be a dead Q10.
Mike
Hairball Audio, LLC
DIY Parts and Kits
Olegarich
« Reply #453 on: August 14, 2018, 02:49:22 PM »
Thanks MIke,
Yeah, it's compresion pretty well, GR is happening i hear it and i measure it on output.
I've changed different TL071, still the same, tried another FET, still the same. Definitely have 2K on zero adj and by the way that function works perfectly, problem with "Tracking adj" trimpot.  Maybe I'll try to resolder this part, it's not that much parts, so maybe I'll find what is broken. Thanks Mike,
edgsil
1176 Rev F/G calibration
« Reply #454 on: October 21, 2018, 08:20:01 PM »
Hello,
I am  resurrecting a 1176LN Rev F/G based compressor which I purchased and built in 2013.  I'd like to recalibrate it, but can't find the videos of the calibration procedure that I followed back then.  The procedures that I found on the Hairball Audio website don't seem to cover the Rev F/G version.  If someone can point me to the correct version of the procedures, I would appreciate it.  Thank you.
Olegarich
« Reply #455 on: October 22, 2018, 02:09:12 AM »
Hey, Videos still there,
Hairball audio - Diy resource centre - build guides. In the bottom there is "Go to page" choose 2. Fet older version calibration.
edgsil
« Reply #456 on: October 22, 2018, 11:40:43 AM »
Olegarich,
Thanks for the response.  I saw those videos, but they seem to be referencing Rev D rather than Rev F/G.  I suspect the calibration steps are very similar, however the meter driver circuits are different (discrete transistor for Rev D, TL071 op-amp for Rev F/G) and there is a 3rd pot (null adj) in Rev D, as well as a jumper with R44.
So for performing the meter zeroing on my Rev F/G, do I simply remove any input signal, set the meter push button to "GR", and then adjust R55 (zero adj) for 0dB on the meter?  Or are there other steps involved?
Thanks again,
edgsil
Hairball Audio
« Reply #457 on: October 22, 2018, 02:06:37 PM »
Olegarich,
Thanks again,
edgsil
There is no null adjustment needed.  You just do the GR calibration step for -10dB.
Mike
Hairball Audio, LLC
DIY Parts and Kits
edgsil
« Reply #458 on: October 22, 2018, 03:31:43 PM »
Mike,
Got it.  Seems to be working fine.  Thanks.
« Reply #459 on: July 01, 2020, 03:56:41 PM »
Hey,
So I've had a pre 2016 rev f/g for years now, working great. All of a sudden, a few years ago, a 60 cycle hum appeared. The hum occurs when the unit is on with no input or output connected (using a 0db 1khz sine wave with scope and just a scope). I can also hear it when its hooked up to a signal chain.  I have been all through the unit many times and re-flowed just about everything a few times at this point, dc voltage rails are good. I can't seem to track down this hum.... Nothing appears to be cracked nor do any joints seem to have come apart. Any information regarding troubleshooting this would be a great help, thanks!
Last post May 05, 2006, 04:27:28 PM
by soundguy
Last post December 18, 2008, 02:32:26 AM
by Stagefright13
Last post May 05, 2009, 10:17:28 AM
by MikoKensington
Last post April 03, 2018, 01:21:05 AM
by iampoor1
