regularjohn
Ah, gotcha. Thanks for the info!
beaversaber said:And finally, the VU meter is pegging in GR mode. It's the hairball one, and I can't seem to find anything wrong in the GR meter driver section of the board. I already checked this section in the meta and couldn't find anything
SaMpLeGoD said:...what's the function of the R2 trimmer at the input's section?
SaMpLeGoD said:I'm trying to rise the input gain of my 1176 Rev F, shoud I rise the R1A and R1C? or can I get more gain rising only R5 (input's pot)
loopermc5 said:Hey all trying to do the q bias on a rev f and it's not doing anything. Then I realized I didnt test any of the 2n3707 for hfe would this effect it if their under 250 should I pull them? everything else has been check 20 times what am I missing? also wont go to zero in gr.......ugh!
mnats said:Not sure why you would need to do this - the Rev F and previous units actually step the input down through the input transformer while the Rev G IC input option has a gain of 1. Check your wiring to make sure it is correct first. If you really need to increase the gain of the input stage, increase the value of R1A. Increasing the value of R5 won't change the gain of the previous stage while R1C will only affect the + signal.
SaMpLeGoD said:Well, It's my 7th 1176 builded, 3xRev J, 2x Rev D, 1x Rev A and 1x Rev F... I even just can wire another 1176 with my eyes closed kidding... the problem is that it compress and work perfectly, but just start compressing about at 3 o'clock, when in the normal behaviour is that it start compressing like 11 to 12 o´clock... so I'm reaching the threshold point to late... I thought the cause could be the input's gain... I saw the schematic and it acts like a buffer at the input, the gain is 1 with the 10k resistors across the opqmps... what do you think it could be?
mnats said:SaMpLeGoD said:Well, It's my 7th 1176 builded, 3xRev J, 2x Rev D, 1x Rev A and 1x Rev F... I even just can wire another 1176 with my eyes closed kidding... the problem is that it compress and work perfectly, but just start compressing about at 3 o'clock, when in the normal behaviour is that it start compressing like 11 to 12 o´clock... so I'm reaching the threshold point to late... I thought the cause could be the input's gain... I saw the schematic and it acts like a buffer at the input, the gain is 1 with the 10k resistors across the opqmps... what do you think it could be?
I've already given you one suggestion but clearly you don't think that it is worth checking. So just measure the gain of the IC stage. As you correctly pointed out earlier, the 1176 has a fixed threshold so if everything is working perfectly it should be as though you were driving it with a 1:1 transformer at the input.
loopermc5 said:ok I was wrong I can do the q bias but I still cant get my meter to zero out I checked all my voltages gone through the schematic checked wiring for the millionth time what else should I look at need suggestions please. :-\
