What resistance readings are you getting from V3 pin1 to ground, and V3 pin4 to ground?
V3 pin1 to ground, 470 ohms
V3 pin4 to ground ,471 ohms
Did you add the extra capacitance after L1? You could just use a single 47µF cap to replace both of the 12µF caps like I did.
yes ,just put a 25uf across the one that was their.
You might need to match V1 & V2 better. You tested all of your tubes, right?
i have no tube tester.how can you match the tubes , can they be matched in circuit ? what should i be looking for in a good match... current /voltage...
skal1
