cantgetnosleep
Hello all and thanks in advance for the help.
I'm building an unbalanced line mixer. It will have 6 stereo unbalanced inputs and 2 stereo unbalanced outputs. I want to be able to send any of the 6 channels to either/both of the outputs using separate pots (so looking down at the mixer you'll see two rows of 6 knobs, one controlling the mix for mix buss A, and the other row of pots controlling the mix for mix buss B).
I have attached the schematic, and it is also available here: http://twin-x.com/groupdiy/displayimage.php?pos=-3400.
The top part of the schematic shows the line input section, taken mostly from a Rane mixer, except that I switched the unity-gain input buffer to an inverting op amp with (what I believe) is 6db max. gain.
The bottom part of the schematic shows the mix buss (this would be doubled for the two mix busses). It is unity gain (?) with output attenuation.
My questions are:
1) Is this a workable configuration for a line mixer? Am I missing anything major here?
2) The input stage has three capacitors. This is how the Rane schematic had it. I was thinking that I could get rid of at least C1 and R1 without too many problems. Are the other decoupling capacitors recommended?
3) Do I even really need an input stage to drive the two mix busses? Or is this too equipment-dependent to say.
I will be breadboarding this and experimenting, but I'd like to get some feedback as well.
Many thanks,
Andrew
My questions are:
Many thanks,
Andrew
