rkn80
Re: Modular multi channel DIY AD/DA Box
« Reply #400 on: August 09, 2010, 04:51:16 AM »
I'm sorry. Currently there is no further development because managing the group buy eats a lot of free time and some members seem not to care about their order and that I already paid for them.  >:(
zayance
« Reply #401 on: August 09, 2010, 05:55:36 AM »
Sad to hear about that  :(, of course this project doesn't seem to be one of the easiest for most people, so maybe that's why they all back up, personnaly, i'll be making your project, and will have a lot of fun i'm sure, maybe even grab a second PCB for having 8 channels, too bad their will be no more development on this, some nice features like USB or Firewire would have been great, but i'm sure there is a way around that, still not into it right now to found out the way to do it...
PS: BTW how many PCB are left in you hands?
Kingston
« Reply #402 on: August 09, 2010, 06:15:04 AM »
Oh crap! I was already looking into configuring this project further with arduino. My first 4 channel input module, AES board and its PSU's are working fine.
rkn80
« Reply #403 on: August 09, 2010, 06:24:23 AM »
Oh sorry, I think there is a misunderstanding. Definitely I'll continue with new modules etc. because I need/want them. I just want to say that the progress will be slower due to a lake of time.
Raphael
P.S. I have ~20 PCBs left.
zayance
« Reply #404 on: August 09, 2010, 06:45:10 AM »
Cool, wow 20 PCB's,i understand why you're pissed off, but i think the more this project continues the more people will be interested, of course it's performance will play a game also, but anyway, thanks for pursuing...
« Reply #405 on: August 09, 2010, 06:36:55 PM »
hoping to get back to this project soon myself.  sorting out power, clocking and maybe limiting in front of 32 channels is a bit over my head at the moment!  suggestions welcome  ;)
how would you compare them to converters you've used previously?  i'll be using them either way, but i'm curious to hear preliminary opinions.
unfortunate to hear raphael.  hopefully once a few more of us get ours up and running there will be more incentive for others to scoop up the rest of them.
There's nothing like the right tool for the job.
And -usually- that's what I end up using...
..nothing like the right tool for the job!
Kingston
« Reply #406 on: August 09, 2010, 07:28:02 PM »
I'm not that far yet. Sound is passing through, measurements come out ok and nothing is terribly out of spec.
rkn80
« Reply #407 on: August 19, 2010, 08:19:07 AM »
I've opened ordering threads for the DAC boards and the AESin boards. You can find these threads here:
http://www.groupdiy.com/index.php?topic=40527.0
http://www.groupdiy.com/index.php?topic=40528.0
Raphael
« Reply #408 on: August 19, 2010, 08:30:22 AM »
Hi Raphael, great to see you making progress with this!
So you won't be offering DAC/AES in as a kit?
rkn80
« Reply #409 on: August 19, 2010, 08:33:17 AM »
I'm thinking about it. Last time I lost money with offering kits :'(. So I'm currently unsure how to do it wihtout being unfair to those who have paid their kits.
Raphael
rkn80
« Reply #410 on: August 19, 2010, 08:34:11 AM »
@kingston: Please, can you email me your measurment results? I want to compare them with my results.
Raphael
Kingston
« Reply #411 on: August 19, 2010, 09:32:24 AM »
I didn't save any measurements... This was a quick connection test because I have a non-standard PSU (using super regulators) and I was not sure it would work at all. I still have a ground loop issue because of this and will have to redo the PSU wiring before I can show any real results. It's pretty difficult with all the voltage sense grounds of the regulators. I think I will just disable those.
horvitz
« Reply #412 on: August 19, 2010, 09:38:47 AM »
Raphael,
I know it's probably not going to be as popular as the AES option, but any thoughts about ADAT in/out?  I've been kind of sitting on the ADC boards I bought from you for a little while because of other projects and the fact that AES isn't useful to me right now.  Thanks!
  Brian
tmuikku
« Reply #413 on: August 19, 2010, 10:01:31 AM »
Raphael,
  Brian
Brian, Mikkels ADAT boards: http://electronics.dantimax.dk/Kits/Digital_audio/index.html -> OptoRec and OptoGen
horvitz
« Reply #414 on: August 19, 2010, 07:11:07 PM »
Very cool!  Looks like that may just do the trick.  And not too expensive, either.  Thanks.
rkn80
« Reply #415 on: August 26, 2010, 03:13:55 PM »
Ok, anybody else having build a ADC unit?  ???
Anyway, I noticed that clocking becomes quite difficult when you try to make a really big unit. My unit has now 12 inputs and 24 outputs. It was really hard to do that with wires. It is really sensitive. As soon as you touch a wire of the clocks or it is a little bit moved because you have moved the total unit you have distorted sound. Then you have to rearrange your cables by moving them a little bit. :( This problem becomes bigger with more modules you use. Eg. with only using 4 ADC and 4 DAC modules no problem but with more modules the problem rises. Later I changed the problem with redoing the wiring. But it has eaten a lot of time to find the best wiring scheme via try-and-error.
Therefore, I decided to change my plans, and do first the design of a backplane/carrier pcb for the small modules. On this carrier board the modules can be plugged in exactly the combination you need. It will also provide a clean supply voltage for the analog parts. On one side there will be a standard connector for extentsion (eg. if you need more channels) with a second board while on the other side you'll have options for connections to the outside world (Sub-D, XLR, BNC with analog audio, AES etc on it).
What do you think of this? Interested? Useful?
Raphael
Kingston
« Reply #416 on: August 26, 2010, 03:25:23 PM »
I have only tested a single ADC unit this far. I have two but haven't tried clocking them together because there has been advices against it (should be done with a master clock unit etc).
which brings me to the question
How did you set up the clocking? Do you have some kind of bench master clock unit, or is one of the boards a master?
rkn80
« Reply #417 on: August 26, 2010, 04:27:55 PM »
I tried two setup:
a) Let a SHARC evalution board generate all the clocks (MCK, BCK, LRCK) and configure all modules as slaves
b) Provide one ADC with a MCK and configure only this ADC as I2S master and forwarding the three clocks then to all other boards.
Brolik
« Reply #418 on: August 26, 2010, 05:14:29 PM »
I think the whole backplane for a modular unit idea is awesome. Less wiring = always better to me. Count me in for one as long as I can fit in one of Mikkels ADAT boards to get them to talk to my Digi 002.
« Reply #419 on: August 27, 2010, 12:36:03 AM »
I definitely favor some sort of power/clock backplane. I'm all for a cleaner build, plus if it solves critical issues it seems more a necessity than a luxury!
Last post August 15, 2004, 10:18:05 PM
by daArry
Last post May 06, 2007, 11:42:22 PM
by SonsOfThunder
Last post January 08, 2010, 06:59:56 PM
by desol
Last post June 29, 2012, 10:45:37 AM
by john12ax7
