Hey guys,
Looking for some tips from the Gates gurus. I have an SA-39 that has a 60hz hum. Can't quite track it down.
So far I have replaced C10-C11, tweaked R43 to 275V, re tubed everything except the 6L7's and lamp, and verified that r44 was within spec.
After adjusting R43, i can no longer get my meter to zero. At the minimum value, the pointer is sitting around +2. I also noticed that adjusting the meter zero pot I get audible "scratchy" noise at the output. Should I be hearing that??
Tapping on any tube makes the hum go away, but as soon as signal is fed thru the unit, 60hz comes back.
Any thoughts?
