Neil
Re: Bo Hansén DI layout
« Reply #140 on: May 14, 2010, 04:57:10 PM »
So which Tranny are you Americans using? All the recommended ones are European companies.
Good question! I'm planning on a Lundahl LL1538 on one, but I'm undecided on the other.
Does anyone have a good suggestion to complement the LL1538? Something a little different sound-wise.
Bo Hansen
« Reply #141 on: May 14, 2010, 09:20:31 PM »
I have now recieve a couple of the first batch of the real final pc-cards, and i will give a big compliment to Soren, Torben and Gustav for a great work on this pc-cards, they are very nice and of first class.
About transformers.
You can use all brands and types, if they are microphon transformers, and if they have a primary on 150 or 200 ohms and have a ratio around 1:5 to 1:10, and of course you must connect them backwards in my DI-circuit.
Higher ratio, (10:1) gives more loss from instrument input to balanced output.
The optimal loss for a active DI-box are around -15dB, to match a console microphone input best, so for a 200 ohms "primary" a ratio around 5:1 will fit best, but up to 7:1 can be ok.
But be sure that you configurate primary and secondary windings right, because some transformer can have a lot of impedance/ratio combinations.
There ar a lot of brands of US made transformers as Sescom, Chrimson, Pico, Microtran, Hammond, and many others.
With advantage can older types of "matching" transformers be use in my DI-circuit, like brands as UTC, Freed, Stancor, Altec/Peerless, Triad, Thordarson, Kenyon, Dukane, and many others US made brands.
But watch up for "microphone to grides" types, they have to high ratio for this application.
--Bo
« Last Edit: May 14, 2010, 09:24:01 PM by Bo Hansén »
I met a man with a dollar, we exchanged dollars, I still had a dollar.
I met a man with an idea, we exchanged ideas, now we each had two ideas.
Soeren_DK
« Reply #142 on: May 19, 2010, 07:13:25 AM »
Hi Bo.
Can I use other transistors instead of the BC550C and the BC560C?
I have a lot of:
BC328
BC338
BC547B
BC557B
Soren
Quote from: idylldon
...it works like a champ and is as quiet as a mouse pissing on a cotton ball.
http://www.soundcloud.com/doctorsclub
Bo Hansen
« Reply #143 on: May 19, 2010, 03:50:32 PM »
Soren,
You can use near all small signal general purpose transistors, that have Vceo 30 volt as minimum, hFE from 200 and up, and fT from 100 mHz and up.
I use BC550-C and BC560-C because this was very easy to get around the world for a couple of years ago, and with right manufactures they was very good  genaral purpose low noise audio transistors.
The pc-card are done for transistors that have TO-92 with pin configuration like a old TO-18 in metal can as BC109.
Here are some other transistor types that direct fit on the pc-card. (not need to twist any legs)
BC550=NPN
BC560=PNP
NPN: BC550, BC549,  BC546, BC547, BC548, all B or C
PNP: BC560, BC559,  BC556, BC557, BC558, all B or C
Here are some older TO-18 transistors in metal can, that also fit direct in the holes.
NPN: BC109, BC108 B or C
PNP: BC179, BC178, BC177 B or C
Then you have hundreds other NPN and PNP transistor, but maybee you must twist the legs to fit in right holes on the pc-card, and you must be 100% sure that you know the transistor pin-out.
Here is some well known NPN and PNP pair that you often can see work together in various audio gear around the years.
As I say before, watch out with pin-out.
NPN: 2SC2240,  PNP: 2SA970 GR or BL (the best pair of all transistors)
NPN: 2SC1815,  PNP: 2SA1015 GR or BL
NPN: BC184,  PNP: BC214 B or C
NPN: BC182,  PNP: BC216 B or C
NPN: BC414,  PNP: BC416 B or C
NPN: 2N4401,  PNP: 2N4403
NPN: 2N4124,  PNP: 2N4126
NPN: 2N5210 or 2N5088,  PNP: 2N5087
NPN: 2N3707,  PNP: 2N3702
NPN: MPSA18, PNP: ------
Of course you can mix all NPN and PNP in a combination.
--Bo
« Last Edit: May 24, 2010, 08:00:28 PM by Bo Hansén »
Neil
« Reply #144 on: May 24, 2010, 12:25:21 PM »
I started building mine, but have two questions-
Bo's schematic on his website calls for a .047 uF cap between XLR pin 1 and Monitor Amp Out (-) but on the circuit board it's labelled .1 uf.
Also, on the schematic right beside the .047 uF capacitor there's a 47 ohm resistor, but on the circuit board it's 100 ohm (right below the two 1N4004 diodes).
Which one is right, or can you use either one?
« Last Edit: May 24, 2010, 12:33:05 PM by Neil »
Bo Hansen
« Reply #145 on: May 24, 2010, 07:51:10 PM »
Neil,
I have done some value correction the last years, but I have not change the schematic yet.
(new tech page with better info will be displayed soon)
Here are all change I have done:
two 470K to 100K
1uF to 10uF
47 ohm to 100 ohm
0,047uF to 0.1uF
So the component value on the pc-bord are absolute right.
--Bo
Neil
« Reply #146 on: May 24, 2010, 07:58:09 PM »
Ok, thanks Bo! I read your notes on the web page but since those components weren't mentioned I thought I'd ask to be safe.
joellegros
« Reply #147 on: May 25, 2010, 10:19:46 AM »
Anyone know if there is a US distributor for the Haufe ST8456?  Went to their website, but it's all in german (someone mentioned I think).  I will probably build one with Lundahl 1538 first, but would eventually like to try out the Haufe.
I came up with a layout with a friend last night, but I think I might try this one since it's been tested.  Also, I think I'm going to use a Hammond 1590CGY to enclose it.
Thanks Bo and everyone who helped make this project possible!
ericjazz
« Reply #148 on: May 31, 2010, 01:57:06 PM »
Hello,
Does anyone know dimensions (height) for the ST8456? Need to choose the right case (I'm thinking of this: http://www.thomann.de/fr/millenium_die_dibox_passiv.htm, but height can be insufficient...).
Btw, if french guys are ok for a Haufe group buy, then pm me.
Thanks to Bo and Soren for this great project.
Best regards.
Eric
[silent:arts]
« Reply #149 on: May 31, 2010, 03:04:29 PM »
yes: 16mm
briomusic
« Reply #150 on: May 31, 2010, 03:49:22 PM »
wow: case, connectors and two switches for €10 - pretty cool  :D
diyfanatic
« Reply #151 on: June 01, 2010, 05:27:47 AM »
Another one @ thomann 58€  With Haufe trafo :o
Millenium DI-Pro - professional passive DI box - Haufe transformer, XLR/jack in, XLR/jack link, XLR/jack out (Haufe transformer), ground lift switch.
 http://www.thomann.de/fr/millenium_dipro.htm
ericjazz
« Reply #152 on: June 01, 2010, 02:42:21 PM »
Thanks for the answers. Millenium DI-Pro is interesting.... I wonder what type is this Haufe transformer.
For your information, I received pricing for 4*ST8456 : 217,55EUR incl shipping to France...
Best regards.
Eric
[silent:arts]
« Reply #153 on: June 01, 2010, 03:08:52 PM »
FYI
I will receive some Haufe ST8456 in the next two weeks.
since I ordered a larger batch I can let them go at
EUR 28,30 each + shipping + 19% VAT (if applicable)
« Last Edit: June 01, 2010, 03:24:08 PM by [silent:arts] »
mrcase
« Reply #154 on: June 04, 2010, 11:01:21 AM »
thats a good deal on the haufe transformers.
do you have them in stock already?
[silent:arts]
« Reply #155 on: June 04, 2010, 12:02:18 PM »
not in stock, but I'm awaiting them next week.
« Reply #156 on: June 04, 2010, 01:18:45 PM »
I'd definitely like to get a pair of those transformers when you get them in.
mrcase
« Reply #157 on: June 04, 2010, 01:29:11 PM »
count me in for 2 please!
[silent:arts]
« Reply #158 on: June 04, 2010, 01:35:54 PM »
guys, I will serve you, but please let us leave this thread to the great DI ...
will post somewhere else once I have the transformers in hand.
neodyms
« Reply #159 on: June 09, 2010, 09:31:08 AM »
hi all !
For every body finished this Project, what's your impressions about the sound, the fidelity ?
Last post June 14, 2004, 07:51:53 AM
by FrankSL
Last post May 05, 2019, 07:16:24 PM
by Ricardus
Last post February 01, 2012, 02:05:19 PM
by MatthisD
Last post September 25, 2018, 02:00:35 AM
by leadpoisoning
