weiss
Re: G-PULTEC problems, please help!
« Reply #720 on: February 05, 2019, 05:28:49 AM »
If i want to transform potentiometers of a dual mono pultec into stepped switches, is it as easy as using the 1x12 lorlins, adding resistors to it (like in the pqd2) and connect it?
i found these pcb's: http://diy-tubes.com/index.php?route=product/product&path=59&product_id=167
might that work?
thanks
gyraf
« Reply #721 on: February 06, 2019, 05:55:13 AM »
I don't see why not? But you don't actually need pcb's for that, do you?
Jakob E.
weiss
« Reply #722 on: February 06, 2019, 06:13:39 AM »
Jakob E.
thanks, yes not really  ::)
petermontg
« Reply #723 on: February 06, 2019, 11:07:38 AM »
Is it possible to control the iput in the amp.
And if so where about would i
Best
Peter
gyraf
« Reply #724 on: February 08, 2019, 01:00:32 AM »
say again?
weiss
« Reply #725 on: February 08, 2019, 05:12:20 AM »
Best
Peter
you want to control intput or output gain?
« Reply #726 on: March 23, 2019, 09:43:26 PM »
Hi all,
Can someone tell me what the resistor values on the Don Audio filter board are? On the original they're marked as 1k, 1k, 10k, and 75r, is that right? If so, what do they correspond to, R1, R2 etc. Cant seem to find this anywhere online.
Probably a bit late but for anyone else needing them they are:
R1 = 75R
R2 = blank
R3 = 10K
R4 = 10K
petermontg
« Reply #727 on: April 17, 2019, 02:41:57 PM »
What I am trying to do is just to control the input into the SRPP.
Any Ideas wold be great.
Best
Peter
weiss
« Reply #728 on: April 17, 2019, 04:15:41 PM »
Best
Peter
You could replace the 10k resistor in front of the SRPP (between filter pcb in and ground next to 220n coupling cap to ground) with a potentiometer to attenuate the signal.
petermontg
« Reply #729 on: April 19, 2019, 08:37:19 AM »
Thanks I'll give it a go over the weekend.
Best
Peter
weiss
« Reply #730 on: May 23, 2019, 07:17:52 PM »
Hey guys,
i built a pultec with stereo potentiometers and dual gang switches from a kit i bought off a member here. But the high section (boost & attenuation) doesn't do anything on both channels..
Low section works as expected. i checked the wiring and couldn't find any loose connections.
Could you give me a hint where to look ?
Otherwise this eq is working fine.
thanks
Ansgar
gyraf
« Reply #731 on: May 24, 2019, 06:28:27 AM »
High boost and high cut are two entirely different functions, so it's probably more that one error. Maybe switch miswireing?
Jakob E.
weiss
« Reply #732 on: May 24, 2019, 07:03:54 AM »
Jakob E.
Oh okay! alright, i'll check.
thanks for the persistent help  :)
weiss
« Reply #733 on: May 24, 2019, 01:01:21 PM »
Jakob E.
Now i completely rewired the 3 switches, replaced the 4 filter boards but nothing changed  :-[
I am not using lorlin switches mounted on the pcb but these front panel mounted dual gang switches:
I put the marked with 1 as the first position of each switch, that should be correct - or not?
Does the  high freq selection switch need connection from the poles to the pcb? It seems they are only connected to each other.
« Last Edit: May 24, 2019, 01:20:15 PM by weiss »
weiss
« Reply #734 on: May 25, 2019, 09:55:01 AM »
i am absolutely confused where this might come from. i used two completely different filter boards and wired all switches from the beginning but still the high section doesn't do anything...   :-[
Is there someone who might have experienced the same?
I am clueless  :-\
weiss
« Reply #735 on: May 25, 2019, 10:41:47 AM »
not sure if this helps..
Harpo
« Reply #736 on: May 26, 2019, 03:51:23 AM »
Ansgar, is this a dual 2x6 rotary switch for sure (4 pole connections) ?
As you didn't fit all wire connections where the joins were made on pcb, you did all (5 per side, 10 for stereo) corresponding joins at the switches poles and throws directly ?
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
weiss
« Reply #737 on: May 26, 2019, 05:43:49 AM »
hey, yes it has 2 poles per channel so 4 in total and 6 positions.
I made all the connections which are needed on the pcb. when no lead was going from the switch on the pcb then i didn't wire it. hope this makes sense..
Like said there is no problem at all with the low section, this is what makes me wonder :-/
Harpo
« Reply #738 on: May 26, 2019, 09:51:17 AM »
For Hi-boost frequency selection, deck 1, pole A and throw 1...6, pole B and throw 7...12. Deck 2 hooked up the same.
You joined throw 1 with 2, 4 with 5, 8 with 9 and 11 with 12 and you joined pole A with pole B ?
(hookup of low section and Hi-cut is different from Hi-boost)
weiss
« Reply #739 on: May 26, 2019, 10:29:14 AM »
yep, exactly what i did
Last post August 16, 2004, 02:08:36 PM
by frob
Last post November 13, 2004, 10:51:40 AM
by Adky
Last post May 23, 2006, 04:51:14 PM
by rubric
Last post November 17, 2006, 05:25:08 PM
by carloff
