Hi Guys,
I have 2 GPultecs fully stuffed, including filter boards and Amp / PSU boards.
I did this before understanding that 1 PSU was sufficient to drive 2 channels.
Im not too bothered about the additional cost of stuffing the boards now its done, but would like to power the pair off 1 pair of toroids. they are rated 15v at 1.7A so I think this should be plenty.
Im guessing I can just take the 15v from the first transformer, then take the 220v from the second transformer and use these 2 feed the 2nd PSU. But would I need to do anything to the section of the 2nd PSU baord that is allocated for the secondary of the 2nd transformer? Or is it OK to just skip that if you already have the stepped up voltage from elsewhere?
Would I need to change the fuse on the 1st PSU at all? On the schemo it seems to suggest its breaking 220, but on the board it looks like its breaking the 15 / 12v line, so Im a bit confused about its role. I assume its there as a failsafe if one of the toroids fails, but I dont really understand much more than that.
As you can probably tell, Im quite far from expert when it comes to PSU stuff, even though I know it should be quite simple!
Thanks a lot
Jake
