oep on g-pultec
champ72
Member
hi
there's a definitive guide to wiring oep a262a2e instead of lundahl 5402 on g- pultec(input & output)?
i tried with "search" but i did'nt find help
thanks
The trafos have a sort of similar pinout, use the mid-pin for ground and wire at will. I think the Lundahl was "reversed" with pins (2:1 step down) in compared to the OEP. I've got the G-Pultec board here on my hand, currently working on it and the Lundahl reminds me of the OEP on 1176 by it's pin layout. So what I think, you could put the OEP "backwards" on the PCB and rewire the mid-pin 3 with a jumper wire to it's appropriate place. Somebody correct me if I'm wrong? I don't know if you need an extra resistor somewhere, think this was the case with the 1176 mnats rev J board.
Dunno if these help, hope so :)
http://datasheet.octopart.com/A262A2E-OEP-datasheet-537606.pdf
http://www.lundahl.se/pdfs/datash/5402.pdf
