Flundran said:Where did you find those rubber mounts visible on the red PCB's? Looks neat.
-The Rubber mounts come with the PCBs
electrochronic said:Many comparisons sited with V72 and R47, are the comparisons based
on the stock V72 or the Abbey Roads EMI Modded V72 (higher gain like a V77) ?
electrochronic said:No , actually there is a trimmer cap in the V72, verified with a real unit , its not just fixed cap value. This trimmer is in
parallel with a fixed cap. So I'm thinking there is some kind of calibration or circuit tuning
in this location. Few folks ever really mention its purpose.
Kingston said:It a high frequency filter for the (rather complex) negative feedback path. It's probably originally there so they could better match frequency response with varying output transformers. Feel free to use it for the same purpose. It's similar to the variable pF range feedback trimmer in LA2A.
guavatone said:Flundran said:Where did you find those rubber mounts visible on the red PCB's? Looks neat.
Yes rubber grommets from hardware store or mcmaster.combruno2000 said:guavatone said:Flundran said:Where did you find those rubber mounts visible on the red PCB's? Looks neat.
I didn't get any mounts with my PCBs, but I bet rubber grommets will work.
Bruno2000
guavatone said:Holger, what does that red line mean? Are you getting distortion?
Is that your noise floor?
guavatone said:did you try to see if the transformers are ringing?
guavatone said:Also. I noticed your Preamp PCB grounds go to the JLM PCB. I got better results running the Preamp PCB
grounds to the star ground which looks to be the rear panel of your enclosure.
