The 14-pin unlabeled chips are most likely some standard quad opamps. Certainly the 100nF (or so) rail compensation caps seem to match the standard quad opamp VCC pins.
TL074 is popular among the guitar pedal designers, and I suspect they are used here as well. SansAmp is probably being clever here smudging out the labels so that people don't realise what cheapskate part was used here.
Changing them to anything else won't fix noise issues, and will likely just ruin the sound and subtly change the type of distortion produced. You will just end up making the sound sharp and nasty with fast modern opamps.
gain, filters and buffers (summing). Not much else they can do. That big black slab of epoxy contains a lot of diodes (overdrive and distortion) and filter caps (probably simple 2nd order topologies) which these quad opamps are buffering and gain staging to create the actual distortion.
I see +/- 15V volt regulators, so opamps are not likely TLC2262 and TLC2264.
Interesting to hear. I had read from numerous sources who have built Tonepad Tech 21 GT2 pedal clones that TLC2262/TLC2264 are what Tech 21 uses to get their 'trademark' sound.
Here's what one person wrote (which is backed up by the people behind the Tonepad GT2 clone):
TLC2262 is the Cmos (all fet internal) rail to rail "version" of the TL062 dual op amp. - low current drain device.
Like the TL062 the TLC2262 has a much slower (slew rate) high frequency power gain, and can sound quite mushy when driven hard.
This feature is exploited by TECH 21 of NYC in their SANS AMP series, for a supposedly better MARSHALL and MESA sound. http://www.diystompboxes.com/smfforum/index.php?topic=59068.0;prev_next=prevSo I am surprised you guys think those might not in fact be TLC2262/2264's with the marks scuffed off. The specs say these chips can take up to 16v, so 15v supply wouldn't necessarily rule them out, I don't think.
Regarding the black epoxy block, just curious - how exactly does that work? Is it like a little circuit board with diodes and caps soldered into it, then they just cover it in epoxy to keep that aspect of their layout secret?
There is also a gentle humming coming from the unit (not in the audio path, just acoustically audible hum in the room if it is on), and I can't see or feel anything loose in the chassis that might be causing it. I am thinking it might be a problem with the power transformer they have on there. If so, I will have to replace that, and I will probably just install some opamp sockets at the same time. As long as I know the unlabeled ones are just duals and quads, there should be no harm in experimenting.
Thanks.
