plumsolly
Re: MK47 assembly - lots of pics
« Reply #20 on: October 20, 2010, 01:40:20 AM »
I think a Thiersch group buy was attempted/discussed a couple of years ago and if I recall correctly the price break was not enough to make it worthwhile.
Best, Ben
« Reply #22 on: October 20, 2010, 04:28:54 PM »
Yeah, I was wondering what kind of price break (similar to Ben's) we could get from Thiersch, en masse...  ???
I didn't find any info on BeezNeez capsules price break. But if there's a appreciable volume discount how about K7 group buy?
Sredna
« Reply #25 on: October 22, 2010, 03:11:39 PM »
It's working!   ;D
After initial problems with the 1uF MKT capacitor, it sounds quite nice also with a chinese K47 style
capsule.
The MKT had almost a total short, maybe 160V is underrated? Had some peaks of 120V during the finetunig of the PSU.
The PSU is very simple: 160VAC transformer, CRCRCRCRCR C=68uF R=500R 10W
The resistors are getting to hot to touch but not to melt plastic, the mic is warm and cosy...
So now waiting for a Beesneez capsule, Skylars housing, burning in the tubes, testing, testing, testing....
Thanks Max for this project!
Anders
Hmm... in which direction do the electrons actually go?
ioaudio
« Reply #26 on: October 22, 2010, 05:53:04 PM »
oh wow - sorry - i can send a replacement, let me know.
160 vdc should be all right (like the original), just bad luck with the cap.
-max
Sredna
« Reply #27 on: October 23, 2010, 09:28:59 AM »
Now continuing with burning in of the tubes.
From the beginning they were quiet with occational pops.
Now, after maybe 6 hours, the pops are still there and are
most frequent at startup time.
Max, what are your experiences with these tubes?
ioaudio
« Reply #28 on: October 23, 2010, 09:56:38 AM »
let them burn in for at least 24 hours.
how did you solve the heater-droper *s heat flow to the housing?
which housing is in use? can you give some voltage readings?
-max
Sredna
« Reply #29 on: October 24, 2010, 12:59:38 PM »
Burnin, burnin...  ;D
Still some snap, crackle and pops but getting better...
Im currently using a SE Electronics Z3300A housing, it's just temporary in the waiting for Skylar's housing.
The heater dropper was soldered with the legs slightly bent as a bow acting as a spring, it's
not that much pressure applied but the housing gets warm and cosy so it works.
Im also thinking about soldering a clip inside the housing tube or maybe install screw connectors on the
PCB and mount the resistor permanent inside the housing.
My readings:
Supply: 105V +/- 0.2V (Variations of +/- 1Volt over several hours, maybe house power variations?)
Heater : 34.8V (Between heater and dropping resistor)
Cathode: 1.3V (Between 27R resistor and pin2/7)
Plate: 43.6V (Obviously too high)
Capsule: 56.3V (At the voltage divider 2M/3M, cant get readings at the backplate)
The plate voltage is about 10V too high, checked the 100k and 30k resistors, they're ok.
Changed to a fresh set of tubes, getting about the same readings but plate voltage is now 50V!
What are your readings Max?
Anders
« Last Edit: October 24, 2010, 01:01:17 PM by Sredna »
ioaudio
« Reply #30 on: October 24, 2010, 01:53:39 PM »
your voltages are ok, including the plate.
do not mount the heater dropper on the transformer*s side.
two solutions: either drill&tap the base and mount the resistor or use some heat conductive glue.
-max
Sredna
« Reply #31 on: October 24, 2010, 02:07:15 PM »
Ok, thanks! Then I can stop looking for Ra of VF14 ;)
Heater dropper is not on the transformer side. Why? (resistor is wirewound=inductor?)
ioaudio
« Reply #32 on: October 24, 2010, 02:11:24 PM »
we do not want to grill the transformer  ;)
Jim50hertz
« Reply #33 on: October 26, 2010, 07:11:57 AM »
Still burnin' and noisy, or better?  :)
"Nasty, talking to a slightly deaf journalist, had claimed only that the Rutles were bigger than Rod."
Sredna
« Reply #34 on: October 26, 2010, 08:17:52 AM »
Its much better but still some occasional pops now and then.
I also changed tubes and the new ones were considerably quieter
from the start and after a shorter burn time almost pop free.
Am now mounting the PSU in a proper enclosure so burn in is on halt but I feel confident
that out of the 6 pairs of tubes I have, Ill find at least one or two working pairs.
« Last Edit: October 26, 2010, 09:20:02 AM by Sredna »
Jim50hertz
« Reply #35 on: October 26, 2010, 08:31:54 AM »
Good news Anders.  :)
Seems like it's definitely worth having a stock of these around.  Thanks.
Jim
Jim50hertz
« Reply #36 on: October 29, 2010, 04:22:18 AM »
Psu - i am currently experimenting with choke / no choke.
The original NG psu was made in two versions - with and without the choke.
Triad 553-C-3X should be nice and cheap.
Hi max, any conclusions r.e. the choke/no choke experiments?
ioaudio
« Reply #37 on: October 29, 2010, 08:07:29 AM »
yes:
1. the choke helps filtering crap from the mains and is a better solution for "poluted" places.
2. unloaded voltage does'nt rise as high as with the resistor-only circuit.
-max
« Last Edit: October 29, 2010, 09:31:59 AM by ioaudio »
Jim50hertz
« Reply #38 on: October 29, 2010, 09:36:07 AM »
Thanks Max, I will go with that then... Do I simply omit the first two 1K resistors and sub the choke in?
nashkato
« Reply #39 on: November 01, 2010, 10:02:32 AM »
the triad inductor series offers different types.
max suggested the 10H , 500DCR , 50mA .
there are 7H / 10H , 240 / 270 DCR , 75 /90 mA inductors , too.
any comments on using another one than the 10H/50mA inductor ?
Last post November 03, 2010, 01:51:16 PM
by pH
Last post October 26, 2011, 01:05:46 AM
by dandeurloo
Last post December 22, 2018, 09:27:25 PM
by glimmertwins
Last post May 09, 2020, 10:11:39 AM
by kante1603
