I thought I'd share this with the community.
I've been talking with Doug at Electromagnetic about the virtues of big 1930's tubes and no feedback circuits. He just about convinced me so I decided to modify my REDD47 clone to save on metal bashing.
With no feedback, you lose possible instability and phase shifts etc, but you also lose the reduction of noise, distortion and low output Z, so you need to correct for that.
My circuit is inspired by the RCA BA-2C.
Through Morgan Jones I found the sweet spot for the E88CC which minimises distortion even with a 100k load pot; the tube is doubled up to reduce noise. I wanted to use the original Sowter output TX so I needed a low plate resistance to drive it, brainwave! use a triode wired EL84!
I found the sweetspot for that by using the ruler from Radiotron on the Plate graph, turns out to be 4~5k for minimum distortion.
I used big HT caps to stabilise the HT and reduce any hum to a minimum and a DC heater supply.
Anyway, I got -83dB noise which is not an issue in practice and a clean output of ~10VRMS into 600 ohms and I love it. I also decided to put a switch on it to adjust the input Z for various mikes (even 500 ohms for an SM57) and that works ok. I did not bother with a zobel after taking PRR's advice and the TX sounds fine.
Thanks to Doug and everyone whose posts inspired this project.
best
best
