Output transformer question
jrmintz
NY
Hi all,
I have two good quality 1:1 output transformers same size, same configuration. I think one is a copy of the other. The only difference that I can measure is in the inductance, which is higher in one than the other. How is that likely to affect the sound? Could they be used as a stereo pair?
how much higher is the inductance?
if one of them has much more primary inductance then leakage inductance and stray capacitance may also be much higher, which will have influence in top end response too...
lo inductance -> less bass (depending on driving impedance), good topend response
hi inductance -> good bass response, limited HF response, ringing etc...
steff
[quote author="Steffen"]lo inductance -> less bass (depending on driving impedance), good topend response
steff[/quote]
This is often true, but not always.
Shunt capacitance usually increases with more turns, so a transformer winding with greater inductance usually has more distributed shunt capacitance. But this is not a direct consequence of inductance itself, but rather a parasitic effect that can be minimized through construction techniques. Paradoxically, the transformer with more windings might have better HF response to some degree (especially if it's a stepdown type) due to increased primary-to-secondary leakage capacitance.
Where's Whitlock? He can explain this stuff much better.
[quote author="sismofyt"]Thanx Jakob :thumb: My Monacor LCR meter went south some time ago and I really need a new one. Cheap! Any suggestions?[/quote]
got this one, 56 euro, measures inductance up to 20H, plus capacitance, frequency, etc...
steff
[quote author="sismofyt"]56euro? Whoha! Where? Frequency? What's the range?
Many :?: , eh? :green:[/quote]
www.elv.de
freq.counter is 200kHz only I think..... but hey, you even get temperature probe with the unit ....sometimes handy for checking heatsinks (no more burning the fingers :green: )
steff
I just got home and measured the transformers again. First of all, they're 1+1:1+1 - two primaries and two secondaries. I'm not sure my methodology is right, though. I measured the inductance of each coil, not from one coil to the other. Is that right? I'm not sure how to measure leakage inductance. Here's what I got:
coils in parallel-
T1 inductance 1.256H, resistance 21.7 ohms
T2 inductance .374H, resistance 22 ohms
coils in series-
T1 inductance 15.8H, 41.7 ohms
T2 inductance 5.3H, 45.3 ohms
So this is telling me that T1 is likely to have more lows and less highs than T2?
Hi there,
can one of you tell me how I can tell wich is the primary and wich the secondary winding on an audio-transformer?
AND: I have some non-pcb-versions: Are the colors of the connector cables standardized somehow?
Chris
[quote author="chriss"]can one of you tell me how I can tell wich is the primary and wich the secondary winding on an audio-transformer?
AND: I have some non-pcb-versions: Are the colors of the connector cables standardized somehow?[/quote]
- There's no way (that I know of) to figure out what way a transformer was ment to operate. And then, on the other hand, it dosen't really matter. There's no intrinsic "right" way to shove signal through a transformer - one way is as good as the other. Depending, off course, on the ratio and inductances you need.
- Wire colours are often standardised within one manufacturer's transformers, but there is no such thing as an universal standard.
Jakob E.
