Blue cactus question
Gus
n
Does anyone one have one. The reason I ask is because I believe it uses Blues version of the kk47. The blue cactus capsule sells for about $400.00 last time I looked thats not too bad a price if the capsule is good.
I am thinking of a um900 grill with the blue capsule for a new microphone build. Any feedback on the capsule sound would be nice.
Seth likes his 900 thats why this post.
what i don't understand is how you get the capsules all by themselves. call blue direct, lie and say it's for repair? what if they want your s/n, or tell you to send it to them? i'd like two blue cactuses if i were going ahead ...
[quote author="Gus"]Look at the date of the posts.[/quote]
i'm aware. i saw no reason to start a new thread.
also to add to the question. i notice peluso has a 47 too now. thoughts?
http://canadianaudiodistributors.com/Index/PK47.htm
Blue used to sell just the unmounted capsules.
There was a link on their site labeled "Raw Capsules" where they sold raw capsules for the Kiwi (U87), Cactus(U47), and Plum (U67).
I can't find them on their site today but you could buy them direct at the time of the original post.
They were $400 ea.
I have a Cactus.
This mic is extremely dark. Before purchasing, I had read a lot of folks' comments on the mic--everyone seemed to agree about its darkness.
I thought "ahhh, these people are just accustomed to modern, super-bright LDCs; it's probably not THAT dark."
Well, they were right--it's pretty damn dark.
I love it, but I imagine the Cactus may not be bright enough for some people's tastes.
I've gotten some ultra-smooth vocals from this mic through an SCA n72 pre.
I tend to use this mic for instruments that I need the highs to be smoothed (i.e. trumpet/flugelhorn).
...not sure how I feel about it on acoustic guitar--I still need to experiment with more patterns to find the optimal fit for my environment + my acoustic guitar, which is kind of dark also (Martin D-35).
It seems that Blue has made several, dramatic revisions to the amp on this mic. It's possible that they may have made changes to the capsule as well over the years--this is purely speculation based on the amp changes: see pictures.
From the Cactus owner's manual (earliest Cactus design?):
My Cactus (made before all the BLUE vs. VIOLET madness):
Newest revision (post-VIOLET split?):
Here's a couple more photos; if you guys wanna see more of the guts, let me know. I don't have a picture of the capsule though--I'm kinda scared about taking the grill off!
Thanks for the pictures Looks like good parts in all of them
First two look like russian tubes. I like the tubes I heard in 19a19s and 19a4s. I wonder if they are the same number. Last version tube I need to look at some tubes to see if I can match it. I wonder what is going on with the two transistors?
First looks like a EI transformer yours looks like a U can't tell if it has a I lam part the last picture looks like U
If you are up for it what are the plate and cathode resistors values? I would guess 100k and maybe 3.9K. 25 to 30VDC at the plate?
I have not heard a cactus does it have that nice low end a 19a19 has?
The picture at the Blue site years ago looked like a k47 capsule IIRC.
All greetings!
On LOMO 19a-19 there is a triode 6с6б (6s6b) or 6с31б (6s31b). On the top two laid out pictures there is a pentode 6ж1б-вр (6j1b-vr), and on a following picture the triode of type 6н23п (ECC88)/6н2п (ECC83).
Sonic
Thanks for the tube numbers I could not read them on my crt.
[Just reporting back...bringing a dead thread back to life.]
Gus,
You are very close, not surprisingly.
plate resistor = 130K
cathode resistor = 3K
I measure 57VDC at the plate.
The transformer looks like it's made up of alternatingly stacked U lams. (I forgot what this is called—someone jog my memory)
The remote pattern voltages vary from 0V (omni) to 35V (cardioid) to 70VDC (figure-of-8).
Slylar
You might want to try this circuit in the body you are working on as a circuit to use in it, try to find the Russian tube.  I would use a different transformer design.
http://www.magmet.com/lamination/duindex.php
It's the stock capacitor.
A google search points to "K73-11" being a Metallized Polyethylene Terephalate or PET film cap.
I believe that would make it Mylar, correct?
Anyway, it sounds great. I don't really have any intentions of swapping it in this mic.
I am going to take Gus' advice and build one of these, so I'll check out other options when the time comes.
I was able to get 20 of these tubes at a 60¢ a pop.
Firstly, sorry to sidetrack with my personal questions:
"They are all the same. Mylar is the trade name used by DuPont."
http://www.diyaudio.com/forums/parts/143675-petp-capacitors-one-best-2.html
Interesting...
