Neil
Re: Send 'N Blend Support Thread
« Reply #40 on: March 21, 2012, 11:38:26 AM »
Mike, wouldn't SPST switches make more sense considering the 2-pin connections on the board? Not that it matters a whole lot, but it might be a little cheaper for the next guy that orders...
Edit: Oops, didn't see Klem had already asked!
klem
« Reply #41 on: March 21, 2012, 08:39:06 PM »
@Neil, you have the better attention to detail than me and brought it to my attention, I was just keeping a tab on revisions for those that come after us.  Speaking of which, TERMINAL BLOCK, 3 PIN, 2.54MM, SCREW DOWN p/n 282834-3 should be qty 22, not 19
« Last Edit: April 09, 2012, 09:39:18 PM by klem »
groovypower
« Reply #42 on: May 18, 2012, 12:57:18 AM »
Just wondering if anybody has the final schematic of this unit. I am about to start building, got the boards off mike, but I'm waiting for the schematics to appear in case I need to do any debugging. I know it's a very basic circuit, but still, I'd like to know just in case something goes wrong... anybody? I asked Serpent but never got an answer about the schematic. Actually if anybody has finished their unit from start to finished I'd love to hear thoughts, impressions and any gotchas :)
sr1200
« Reply #43 on: August 16, 2012, 10:43:41 AM »
Just wanted to know if i messed something up.  When the unit is switched to BYPASS it puts whatever effect you have in the dryout wetreturn INTO the signal chain.  I would have thought bypass would have been the effect OUT and the unit acts as just a pass through.
MEI Studio - Long Island, NY: http://www.meirecords.com
ruckus328
« Reply #44 on: August 24, 2012, 11:35:27 PM »
Yea, sounds like you miswired something.  Bypass just makes unit a passthrough (puts wet signal direct to the output).  Look on schematic on Page 1.
Serpent Audio™ - SB4000 & SA-3A Boards & Parts Kits / SB4001 Preorder / Send 'N Blend
www.serpentaudio.com
DOMC Mastering
« Reply #45 on: August 30, 2012, 07:43:43 AM »
quick question and possibly more to come as I finally finished this build today.  Should I not have wired up channel 2 and channel 4 pot to the board as well as too the dual pot (I have a dual pot on 1 and 3).
DOMC Mastering
www.domc.com.au
sr1200
« Reply #46 on: August 30, 2012, 04:00:26 PM »
OK so it IS wired right, the SnB is Bypassed (making the output straight 100% wet) cool.  Awesome toy BTW... might need to do another one of these soon!!!  Love me some parallel processing!
groovypower
Photo of a Completed unit!.... and sadly I have to sell it :(
« Reply #47 on: November 08, 2012, 09:17:32 PM »
Guys,
I only have GREAT things to say about the Send 'N Blend! It performs very well in the very small amount of time I've had to try it! Just thought I'd post a photo of my completed unit:
***SNIFF SNIFF*** The down-side about the whole thing is that I have to sell my precious unit due $$ constraints (I KNOW, after ALL that hard work) - sadly this is not even a decision I get to make myself...
Anyway, there are tons more photos of my completed unit over here at my black-market classifieds thread (scroll down once you get there), but I don't want to cross-post all of that with this thread. Just wanted to share a completed photo since I haven't actually seen one ever on this forum.
labak
« Reply #48 on: December 07, 2012, 03:23:11 AM »
Hi all!
Great project!
I just wanna know, if i wanna it unbal, do I have just to avoid the line recievers and drivers?
Thanks.
Best regards.
Chris.
EmptyMusicBox1
« Reply #49 on: January 20, 2013, 08:53:33 PM »
hello
Can i use the SEND'n Blend PCB circuit INSIDE the SB4000 ?
If i use the Audio Input and Ouput circuit with the +15v -15v of the power supply of the compressor ?
i know if i take the PCb , i use 50% of capacity of the circuit ... but i want my Blend circuit on my SB4000 ;)
Thank you for your help
labak
« Reply #50 on: January 30, 2013, 05:50:37 AM »
Hi all!
Is that possible to use stepped switches instead of pots in this beast.
Best
Best regards.
Chris.
labak
« Reply #51 on: January 30, 2013, 03:08:00 PM »
Hi again!
Is it possible to run this beast with a +/- 15v power rail?
Thanks.
Best regards.
Chris.
dmp
« Reply #52 on: May 02, 2014, 02:13:03 PM »
Just starting to build this now.
Was wondering if anyone had modified this so the bypass removes the effect, i.e. puts dry signal to the output.
Looking at the schem it seems the relays are setup to allow this - just needs some traces cut and some wires run?
taliska
« Reply #53 on: July 19, 2014, 09:40:22 AM »
I was thinking about building some of these sometime soon. Did you manage to make the bypass->dry out mod work?
Kaz
dmp
« Reply #54 on: July 21, 2014, 12:13:04 PM »
I haven't tried it yet. I am about halfway done stuffing the board. I think I'll try it before the mod.
« Reply #55 on: February 20, 2016, 04:08:31 PM »
Can anyone who has made this give a rough total cost of the build?
« Reply #56 on: February 25, 2016, 05:42:42 AM »
Can anyone tell me if these pots are suitable for this build ?
with many thanks  :)
http://www.mouser.es/ProductDetail/Bourns/PTR902-1220F-B103/?qs=h2IHEVivlqAvnx%252bOskUPzQ%3d%3d
gaetan
« Reply #57 on: April 25, 2017, 09:06:40 AM »
Hi
The link to the BOM doesn't work, are the files and PCB still available?
SIXTYNINER
« Reply #58 on: April 27, 2017, 05:53:48 AM »
Hi
and this one too
http://www.groupdiy.com/index.php?topic=50405.msg638602
>>" 1 Picture say what billions words cannot "<< - >>"SMD Kill the DIY STAR"<<
Why in the  forum  if no share
hugo
« Reply #59 on: June 30, 2017, 07:14:51 PM »
Are there some builders confirming there are not any loss (in term of sound )by using this ?
Last post April 28, 2014, 09:48:49 AM
by MaNiAC
Last post November 21, 2020, 04:33:56 AM
by ipindalieson
Last post December 09, 2011, 03:31:27 PM
by dandeurloo
Last post February 19, 2021, 03:21:27 AM
by znjamznjam
