I have been testing a VTL5C3 low cost Vactrol. The spec says its resistance should be around 30K ohms at 1mA current but I measure about 7K. I have checked at a range of currents and in all cases the measured resistance is less than a quarter of what it should be according to the data sheet. I am confident the currents are correct as I am feeding the LED via a 10K resistor from a variable supply and measuring the voltage across the 10K so 10V = 1mA. I am using a regular meter to measure the cell resistance and I have checked the meter on fixed resistors of similar values to verify it is reasonably accurate.
So I am puzzled as to why I get consistently wrong values. Anyone had experience of these or can how any light on the subject?
Edit: I bought two of these to play with so I just connected up the second one to make sure I did not have a broken one but I get very similar readings.
