Jean Clochet
I'd forgotten there was another thread discussing what this whole circuit was intended for so yes, linear pots
Yep. I was responding to the "how do you tell which pot to use" question so no harm done here either Mbira
"Small Signal Design" by Self goes into this and determines that, with a 10K linear pot, a 4K7 value pull-down fits the logarithmic curve best. That ratio seems to work well in practice too IMHO.
BTW, standard (read cheap) log. pots don't fit the curve especially well either and cheap linear pots with a pull down will have a closer tolerance.
Again, it won't make a huge difference but, just for completeness, the attenuation at 50% with a 10K linear pot is:
4K7 = 9.73dB, 3k3 = 10.91dB, 2K2 = 12.61dB. No other load on wiper of course.
MagnetoSound said:There were two questions being asked.
Some of us were responding to the 'rule of thumb' question in Mbira's third post.
No harm done.
It won't make a huge difference. In classic Neve desks, I've seen a 5K linear with a 5K1 pull-down (47K in parallel on the amp side) but that's for the 'set it and forget it' bus amps.Brian Roth said:I have seen circuits in some desks (certain Neve and ADM desks).... Typically, the 'slug' R was 1/3 or 1/4 the value of the R of the pot.
