Hi there,
I've been using, as most guys around here when going stepped, those that Uraltone sells as seen here:
http://uraltone.com/kauppa/product_info.php?info=p1077_Rotary-switch--2x24.html&XTCsid=qmeg0cc5g0cvbe2j9v6foqpke3And as most know it's a time killer and a PITA to solder those resistors around, get the right values within 0.1% if need precision etc....
So the day i came across them i also saw that some evilbay sellers were proposing some already assembled with smd resistors one...Pin to pin soldering, doable, but needs some care....
And it got me thinking why not make a pcb that would help soldering those 0805 0.1% resistors onto the pot itself. EDIT: maybe 1206 size resistors
The idea would be to first solder the resistors on the PCB, dismantle the pot, solder the round pcb to the pins and voila, wire directly on pins also...
Of course people that are afraid of those Evil SMD parts would backup, but it's actually faster to solder 0805 and even simpler for 1206 ones compared to thrue hole when you get your marks. And 0.1% gets that matching job away...
But anyway, i've designed a PCB that would fit the pot, i'm still checking some things to do, but i'll be ordering a couple just for my needs i think, more if people could be interested? and this will actually maybe help me think of finalising the Stereo Sontec in a more "Mastering" level, using all 0.1% resistors ala goldpoint, but you can call this cheaperpoint haha...
Well didn't get into the numbers still, but it could be cheaper than Goldpoints.
It would be a 1.2mm thick PCB, there is a little triangle marking place, where it's possible to write down the configuration of the resistor net to keep track before soldering them in place.
What do you think?
Any ideas or comments are welcome.
