Thanks again for the kind words.
Yes i tought so also, not much outer size added, the strict minimum.
There is also tons of offers on Evilbay like this, it's actually one of them that made me think of this PCB, some had the SMD resistor soldered across the pot legs, tricky but doable...
This helps you get a "budget" goldpoint switch in a way, use 0.1% resistors and there you have it, and has a "practice facility" imbedded
, and it's way easier to solder, believe me
Since it's DIY friendly, you can make yourself precision log pots with values of your choice and you can also add stops, drilling a hole and adding a Resistor leg and a drop of crazy glue, will show some pics of how Dagoose came with this nice idea as well.
Of course the overall price is more than 18$ for a Stereo pot, but you'll use higher quality resistors, well if this is an important factor for you?
dagoose said:Brilliant!
And i think that the thing we talked about (outer size) will not be much of an issue really. I thought that it would stick out more then it actually does.
kato said:Recently came across this post that might interest:
DIY Stepped Attenuator Volume Control. Prebuilt for $18. Seems impossible.
BTW Nice design Zayance, yours is infinitely cooler.
