I have been given a MXL V67i FET mic to have a look at. It has not been used much and is in excellent condition. When last plugged in to be used in the studio there was no audio output. I checked it out on my mixer to see if there was any difference and found a strange phenomenon. Sure enough, when 48v. was switched on, there was no audio, but when I switched off 48v. the sound level came up to normal for a couple of seconds before fading out. That was a consistent pattern from either side of the mic (two diaphragms) and I repeated the same test a number of times with the same results. I have not had much chance as yet to check voltages, etc. inside the mic. The red LED inside the grille to indicate which diaphragm is in use lights up, which would show that power is getting to the circuitry. Could it be one of the decoupling caps in the polarizing section is bad? What else should I look for?
Anyone had this same experience, or has anyone have any ideas about why the mic might be behaving like this? Any suggestions or help would be much appreciated.
Kindest regards,
zephyrmic
Kindest regards,
zephyrmic
