audiophreak
Could someone school my Newb butt why most regulated Tube heater circuits , loaded with tubes or not hooked up to any load stay at the correct voltage - 6.3 or 12.6 but as with the Gyraf regulated HT circuit for the G9 and one other I found in the forum , the voltage rises well over the desired voltage for a few seconds while the heaters heat up then comes down and settles at the desired voltage.
I mean I know that the heaters need to heat up to load the HT - but why does the heater circuit stay set at the voltage wanted with or without a load and the HT / B+ doesn't ???
