- Joined
- Jul 15, 2009
- Messages
- 2,299
D-M49c and D-M49b Build Thread .
M49 Round Body version thread here : http://groupdiy.com/index.php?topic=60108.0
M49 mic body available here : http://www.groupdiy.com/index.php?topic=52563.0
All the info Here : http://www.groupdiy.com/index.php?topic=49675.0
The Safety Manual and Considerations.
https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a0357d.pdf
IMPORTANT:
You Should always have the SHLF Jumper in position in the PSU PCB , this will ensure that your cable shield is tied at both end of the cable and connect to 0V
you Should Also have the 0V star grounded to your case and then from there to you IEC earth ground ,
For More Information on Grounding
https://www.dropbox.com/s/6y121dasm3iw4ba/Sound_System_Interconnection.pdf?dl=0
Dan,
BOM
Note: missing from the BOM Styroflex Capacitor C1 1000pf, C6 560pf / 630V
PSU 2469 passive
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=532017ac2f
M49 C or B Mic Parts
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=f556c18411
Schematic: M49C https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a040b7.bmp
Schematic: M49B https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a040c4.pdf
M49 Schematic Poctop PCBS 49b and 49c
https://www.dropbox.com/s/ym5f8tur4y0rgw8/49c-round.jpg?dl=0
https://www.dropbox.com/s/wcym8uf65ov84vi/49b-round.jpg?dl=0
Dan,
PSU Schematic : https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a040e7.pdf
Note : the Toroidal tranformer secondary is wired in parrallel to get 120V at the input of the psu
Cabling connection From PsU https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a0410e.jpg
The 20Vac traffo for Europe will not fit as per the current BOM please replace it with this one or an equivalent ,
http://www.mouser.com/ProductDetail/Hammond-Manufacturing/186B20/?qs=sGAEpiMZZMvwUzoUXIIvyQPvPmwnNFGyR%2fQB%252b1BzrOY%3d
also The fuse will be 0.1A instead of 0.2 for America
M49B Overall Connection and Silk Screen https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a04129.jpeg
M49C Overall Connection and Silk Screen https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a0413b.jpeg
The Safety Manual and Considerations.https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a04147
5840 Tube Datasheet https://cdn.groupbuilder.com/groupdiy/u/39511/58d1402a0415d.pdf
D-M49c
install the floating pin First. ( cut the other end of the pin on back of pcb but leave full lenght the one from Fgrid
Note: To Operate S2 Cardiod only Switch
IMPORTANT:
Dan,
BOM
PSU 2469 passive
Dan,
Connection For AMI T49 to PcB
TRFO to Mic PCB
A- 4
B-3
C-1
D-2
For Converting the 5840 Tube to a Triode Tie pin 7-5 Togheter Do not use Pin 4 or Pin 8
D-M49c
