Mnats 1176 rev D
Sillen
Sweden
Hello
Anyone that built this one here? Regarding R44 (Tracking adjust trim pot) on the PCB.. On the pcb it says it should be a 2k trimmer resistor on R44 but on the BOM page it says that there should be a 1k trimmer resistor on the R44 spot. Hmmm and I got neither a 1k or 2k trimmer resistor for some reason :p
Anyone know anything about this?
Ok thanks! And by the way on the ratio circuit board there's supposed to be 2 lorlin rotary switches right? Because they weren't on hairballs audios finished cart either. Sorry for the newbie questions, it's my first build :/
/Isak
Rotary switches, right, lorlin, I'm not sure. I've used Alpha switches like the ones on Mnats site (there's a ref on the slam ratio guide). Hairball provided switch bank like on original 1176.
Good luck on your build. Take your time, organize your wiring and everything should be fine !
Ben
Another question comes here if anyone knows about it.
The zero adjust, R71, does it work with a 2k trimmer instead of the potentiometer? And btw how do I attach all the knobs to the potentiometers? :p
Yep, a potentiometer is a trimmer.
For the knobs, it depends on your pots and your knobs. Usually you screw them on the pots.
At the Q bias calibration step, could you simply desolder pad 22 instead of shorting it like in mnats video? (since I don't think i have the equipment to do so)
You should look at post in the dedicated thread...it helps people building it to benefit from yours and their questions :)
