theoverstayer
Active member
- Joined
- Dec 16, 2004
- Messages
- 43
I built an amp based on the tori amp posted in late december for my 32 ohm phones - it sounds great. Reading on headwize (which seems to be down now) an article on opamp based amp designs suggested replacing the 50 ohm resistor with another component (which I can't remember) in combination with a resistor to be a more accurate current source which would improve linearity of the amp. Can you suggest what this component may be and do you recommend trying this? I really enjoyed experimenting with this design.
THanks, JEff
THanks, JEff
