john12ax7
Try OPA1678/79 instead.
Why not OPA1641/42? More expensive but superior performance.
There are some producers, like Joe Baressi, who change monitors for each album they work on in the hopes that the new “lens” will help create a different outcome. You may or may not like this approach but it is certainly valid.One interesting thing he mentioned is that he buys old consumer stereo-systems to use as headphone amps instead of dedicated studio headphone-systems or the ubiquitous Crown DC-60s with distro or whatever, and it got me to thinking about that as I read this thread...
One thing that was not obvious to me right away was what appears to be a bootstrap capacitor C19 from the output to the junction of the R43 and R52 resistors that provide the current path to negative supply for the Vbe spreader.
The bootstrap capacitor acts as impedance multiplier.
Thanks for confirming. You do not usually seem hesitant about having an op-amp drive relatively low impedances, so I just wanted to confirm there was not something more subtle going on.
Last time I looked one of the BUFs was very expensive
Yup less than $4 in the USA from mouser or digikey which I feel like is great for what you get especially considering the price of the originalI ran across that mentioned BUF634A recently and was shocked at how much less expensive it is than the original BUF634. Under $4 in singles, and the old design is about $15 in singles.
With a slew rate spec of 3750 V/us, who can complain!
Yes, that is literally how those ICs are intended to be used. The stability concern is delay/phase shift and indeed those are fast enough to be stable added inside most feedback paths.That is completely ridiculous for audio, but the nice thing about that is you can put it inside the feedback loop of any op-amp that you would reasonably use for audio, and just not worry about it. The bandwidth is so high you don't really have to think about changes to loop gain and how to compensate to maintain stability etc.
Headphone amps are as easy or difficult as you want to make them. Back in another lifetime I design a dedicated headphone amp (HB-1) that drove both legs of the headphone for 2x the voltage swing, 4x the power. This is arguably over kill. I design many for use inside mixers with more modest power.And it is nice to have just a few extra pins to solder (compared to e.g. discrete transistors plus biasing components, even though you do have to think a bit about thermal flow with the SOIC package, and the package with center pad is harder to solder).
On the one hand I hear "that is so easy to make a headphone amp, just throw down an op-amp, this buffer, and done!" and on the other side I hear Thor whispering in my ear "Bah! $4 for a buffer, I could make that with 62 cents of transistors and resistors, real engineering considers the cost/benefit ratio as well."
And on the other other hand I hear "you don't have cheap labor putting yours together, are you really willing to spend all weekend soldering down resistors just to save $3?"
