did the dissection but never wrote it up,
Dissection Thread>
http://groupdiy.com/index.php?topic=35548.msg436342#msg436342
Y-6431 = Fairchild 670 Control Amp Input,
this is the one in the big square can,
it is just like the UTC A-10 and HA 100-X except:
the lams are of a lower perm alloy (50/50 Ni)
there are cu foil screens between the pri and sec winds,
turns ratio is 1:9.6 instead of 1:10,
and the hookup schematic has a cross coil configuration,
this means that the the top lead of the pri is connected to the A coil, and the top lead of the sec is connected to the B coil,
so the Pri consists of S-F-F-S and the sec F-S-S-F,
a few other UTC's do it like this like the LS-68,
i do not know what this does to the response or leakage, fun to do an experiment and find out some day,
let me know if you see any errors,
Dissection Thread>
