Hi guys,
I just finished one of my rather challenging projects so far and wanted to share it with you guys here on GDIY because this is the place I learned all I know in terms of electronics and building gear - and I'm telling you it's so inspiring what so many of you contribute to this forum! Thanks!
So I thought maybe I can inspire others, too
First of all thanks to Jim (Bluzzi) for offering the pcbs for the EZ1084 project - they are absolutely HQ and make it very easy to build a 1084 EQ - even easier if you use Dan's case for it.
But for my build I wanted to go some steps further in several ways:
- 2 channels in 2RU enclosure, all parts stereo-matched
- 24-pos step attenuators instead of pots (most pots measure 20% tolerance, my ladder-step-attenuators are at 1% tolerance)
- concentric switches as per the original
- one gain switch per channel which controls both mic and line stages as in the original (with EZ1084 + EZ1290 you usually need two separate switches for Mic and Line)
- frontpanel layout as close to the original as possible
- output attenuator switchable via push-pull pot so it's only in the signal chain if output attenuation is needed
- still enough space in the enclosure to retrofit 2 of Bluzzi's EZ1290LE pcbs in there when they become available
Ok - first started populating the pcbs - measuring and matching the parts for the 2 channels for possible stereo use. Since populating the pcbs is documented perfectly well in Jim's build manual I won't go in too much detail here.
The only difference for me here was, since I wanted to use a 22pos gain switch with 7pos. for the Line stage (+ OFF pos.) and another 14 pos. for both mic stages (incl. another OFF pos.) I had to alter the number and values of the gain switch resistors compared to the EZ1084 (which is Line signal only and offers 11 pos. for line signal)
I used the original Neve schematic to find the needed values and wiring and made the changes to Jim's layout as needed.
To get both channels into one 2U enclosure I had to stack the pcbs
