Samuel Groner
Not related to the well know rock band! :grin:
Look at this schemo: [removed]
I've seen this on very few designs and would love to know more about the math behind it. The idea is to use separate feedback paths for AC (the 10k in the schemo) and DC (R1 + R2). This allows to use smaller ('lytic) caps which have lower leakage.
Now my questions:
* how do I determine R1, R2, C1, C2 and C3? From what I've seen, Rx=25k and Cx=100 uF should be OK, right?
* what's the math behind the low freq roll off (i.e. the -3 dB point)? Is the roll off 1st or 2nd order?
* If R1>>RGain, R1 and R2 do not influence AC gain, right?
* if used in the first stage of an instrumentation amp (three opamp config), it would be wise to connect C2 not to ground but to the opposite cap - similar as we would do it with RGain?
* why is this not used more often? Seems to be a neat trick that does not only improve performance but could save money as well (smaller caps).
Thanks for the help and sorry for so many Qs!
Samuel
Now my questions:
Samuel
