If we go into the way back machine tantalum caps had lower ESR than aluminum caps so were better for some applications. BUT modern aluminum caps now have lower ESR than before (especially the aluminum caps designed for use in switching PS).RuudNL said:It seems Neve used tantalium capacitors for a special reason.
According to Geoff Tanner (ex Neve) the sound changes if you replace the tants by aluminium capacitors.
As he puts it: "Those tants aren't there without a reason".
(Don't know how true this is. Personally I never heard much difference. Maybe it is the same discussion as with speaker cables...)
If Studer say solid alu it's not a tantjtvrdy said:so the cap in the atached picture is tantalum?
I fully agree with you, but still some people think they hear a difference in sound...JohnRoberts said:The type of electrolytic cap used shouldn't change the circuit's sound.
RuudNL said:I fully agree with you, but still some people think they hear a difference in sound...JohnRoberts said:The type of electrolytic cap used shouldn't change the circuit's sound.
(In my opinion you think you hear it, because you know something has changed!
But I suppose the discussion about the 'sound' of capacitors will go on for ever.)
zamproject said:If Studer say solid alu it's not a tantjtvrdy said:so the cap in the atached picture is tantalum?
http://www.vishay.com/docs/28354/128salrpm.pdf
Zam
jtvrdy said:Hi,
in the schematics (Studer A820) is indicated as 1uF "sal" (solid aluminium) it is the same as tantalum cap?
the voltage is rated 40v or25v?
ricardo said:But there is one application where the audible difference between Tantalums and Aluminium Electrolytics is NOT insignificant. Tantalums are truly EVIL for very low noise.
I first encountered this circa 1980 in a MC head amp with noise around 0.28nV/rtHz (ie state of the art noise performance). The latest was in a microphone design of mine built by someone this year.
I don't know for sure but I don't think its either Johnson hiss or current leakage. Tants have very low leakage though by 1980, some aluminiums (eg the Panasonic Lo Leakage) would rival them.JohnRoberts said:ricardo said:But there is one application where the audible difference between Tantalums and Aluminium Electrolytics is NOT insignificant. Tantalums are truly EVIL for very low noise.
Just to be clear are you talking about Johnson (thermal) noise from the ESR, or current leakage noise from a DC bias?
Thanks Zam ! I will look at this Vishay 128 sal-rmpzamproject said:If Studer say solid alu it's not a tantjtvrdy said:so the cap in the atached picture is tantalum?
Zam
jtvrdy said:Thanks Zam ! I will look at this Vishay 128 sal-rmpzamproject said:If Studer say solid alu it's not a tantjtvrdy said:so the cap in the atached picture is tantalum?
Zam
I would be suspicious of granularity in the current leakage. I have seen problems with aluminum before.ricardo said:I don't know for sure but I don't think its either Johnson hiss or current leakage. Tants have very low leakage though by 1980, some aluminiums (eg the Panasonic Lo Leakage) would rival them.JohnRoberts said:ricardo said:But there is one application where the audible difference between Tantalums and Aluminium Electrolytics is NOT insignificant. Tantalums are truly EVIL for very low noise.
from 1980 "Tants give a crackly, popcorn almost like 1/f noise or insufficient dither. "
from 2015 "He found if C1 is a Tantalum, it is prone to whooshy LF noise"
Neither of these are Golden Pinnae imaginings. You just need to feed the DUT into something with enough gain to clearly hear the noise floor without other distractions.
If anyone has a theoretical explanation, I'm all ears.
BTW, the noise of different Aluminium electrolytics sound different in this 0.28nV/rt(Hz) situation but the noise of the Tants was objectionable.
I should try to replicate the tests in da 21st century now that its easy to do spectral plots of noise 8)
Tantalum is also a conflict mineral so another reason to avoid, while Dodd-Frank legislated that vendors certify their supply chain. One cap manufacturer bought their own tantalum mine to prove where it is coming from.madswitcher said:Tants - avoid the little buggers.
Always go short on me particularly when put across the PSU rails - grrrrr
Mike
sodderboy said:That's a tant cap. Studer docs are made by humans. Replace like with like and get on to the music.
The Studer multitrack manuals are full of misprints and language errors. Prove me wrong.
Mike
