Andy Peters
One of these board preheaters showed up in the R&D area at work. And one of the guys has one at home, too, and he said that it (so far) hasn't burned the house down. So for $125, I sprung for one.
Why the board heater? You need it for SMT assembly. Take a look at how they do automated SMT reflow assembly at a stuffing house. You put some solder paste is put on the pads (a stencil helps if you have a lot of parts) (and you really want solder mask on the board), the parts are placed on the boards (get your tweezers and magnifying goggles), and then the board is put on the heater with the temperature set to ~150C. Let it "soak" for a minute. Then take your hot-air tool set to about 220C, with moderate air velocity (so you don't blow parts off the board!) and wave it over the parts. The parts will settle into position by the surface tension of the solder as the solder melts and becomes liquid.
After you finish all of the parts, let the board cool, and when it's cool, wash it. Or use solder paste with a no-clean flux.
It's a lot easier than trying to solder with the standard tool, and required for parts with thermal pads on the bottom.
Also the board preheater and the hot-air wand make removing parts from a board a lot easier. Done right, you won't rip SMT pads off of a board.
