Pip
After much pondering and building of mics I have drawn some of my own, granted biased, conclusions.
1. Tubes are great both for the way they sound and the ease in which they can be implemented. But they are noisy prone to microphonics, distortion and sonic artifacts that are hard to ignore, though they are musical for a lot of uses. You also need to go through a small s**t load sometimes to find one that is microphone grade. They also fail eventually and are HOT HOT HOT!!!
2. What is our reticence when it comes to FET based solidstate mics to use an outboard PSU? I get the use of the phantom power standard when in the field and working live, sure it makes total sense. But when in the studio who cares! Lord knows I have done sessions with a bunch of tube mics and had PSU's all over the place, whats a few more if it means a qualitative advantage? I have also noticed that most consoles don't really have the current capacity on the phantom rails to get the job done.
3. As I have played around with mic circuits and looked at many more schematics I have come to the conclusion that for most microphone impedance amplifier designs FET based is the way to go. They are cleaner, smaller, cooler, stable, plentiful, cheap, have tight manufacturing quality control and are easy to design with. They also have high input impedance which as we all know is very desirable for mics. There are also a lot of choices both in op amp and discrete variety.
4. An outboard PSU allows for multiple power schemes in the same circuit without the need for things like DC to DC converters for capsule polarization and dropdown resistors. They also allow you to look at multistage active conversion to output amplifier designs. You can even go as far as output circuitry that goes to line level and even digital output. A dedicated PSU starts to allow us to look at chips VS discrete topologies or even hybrid designs. They also allow for not using interstage coupling caps as servo designs can be employed.
5. I have always seen phantom powering as a compromise for ease of use but never a reliable robust solution for microphone powering.
In my next post in a few days I will propose some components I have pondered over for various uses when it comes to this subject I look forward to the groups comments.
