ricardo said:
My MOTU Traveler is only P38V doesn't meet P48V specs even when fully working (?!) ... but MOTU calls it 'phantom power' with no specs
Is that the essence of the problem? I understand it prevents you using your numerous vintage U47's and 87's
, but most mics work quite well with reduced voltage, not mentioning those that are specified for 9-52V.
But iI thought your issue was with the input caps that got leaky/noisy. Fixing the phantom voltage issue would not cure this, unless there is another problem...? In that case, that gives you at least three reasons to bin the MOTU and replace it...without any guarantee it will do you better service...
