If anyone is interested the ratio is 11.6:1.
Pretty high.
I always was thinking that CCDA circuits have low ratio transformers.
Probably by some buls..t "stories" over the web.
What a surprise...
I had in mind to use low ratio transformer like 3:1, but forget it - there's no way!
I can't say much about original transformer quality, because i throw it away very quickly.
Overall microphone out of the box sound pretty sh.tty.
Why?
CCDA circuit? NO! It's pretty good topology!
Capsule? - NO
Transformer? eee... response is pretty linear from around 20hz, so maybe not.
High polrisation voltage? Part of true, but with higher voltage than it's set, it can sounds even better.
Infamous 100nF RF capacitors? - sorry all the online "modders" but removing it change not much... The legends says that if you remove it, you will get almost U47 Not true. Of course they can be removed or changed for lower value, but still microphone sounds nasty.
So maybe capacitors quality? It's a part of true, but only a small part. If someone believe in that, micandmod have really nicely overpiced kit for these microphones. Few capacitors, overpriced chinese "made in france" k47 or K67. "With this kit, transform your microphone into C12, U47 or U67". Whoaaaa, what a bulls.it!
12AX7/ECC83 - yes, this is really big problem here! Do we need 6072/12AY7 instead? No not really - finding good, not overpriced 6072 is really hard. Sorry but EH 6702 for me sound really weak - not worth completely. Good (not from current production) 12AT7/ECC81 will be enough. Am using currently Siemens ecc81 made in Munich. Really good tube.
Ok, so what's the real problem with this microphone?
Overall gain is set to high! That's why these microphones sounds thin and overbrighted.
Going down with the gain i was able to use 6:1 transformer and it sound really good, especialy if we take into account the price of this microphone and not really many changes (ok i changed all the electronic parts inside the mike, but it is not necessary).
Final version will be made after "resurrection of the easter bunny" holidays, so maybe i will put here some voice samples.
If someone is looking for cheap tube mike, it's worth the effort and money.
It wouldn't be "hi-end" mic anyway, but all these clones with chinese capsules (even these overpriced) aren't "hi-end" also
Pretty high.
What a surprise...
Why?
Capsule? - NO
