Ptownkid
What is the "right" technique to use for soldering?
I've heard several times that you should not put solder on the tip of your iron and then place it on your connection. Is that just because you want the connection point to be warm as well for a better bond? I'm told that you should hold your tip to the connection and then touch the solder to it. Is this the best way and are there any downfalls to putting solder on your tip first?
Bryan
Bryan
