ruffrecords said:Do you have any data on them?
hugo said:Hi Ian,
There are 1 pair of utc A-10, triad HS-29, HS-56v, marinairs T1444, T1452.
I do not have them in front of me, i do not remember the pins layout...but i will add it if needed
thank you
ruffrecords said:OK, so you have pin out data available. As a first test just check continuity of each winding. 600 ohm windings typically have a dc resistance of a few tens of ohms and 10K windings can be as much as 1K or so.
CJ said:dang, where did you get the HS-29?
no, but who is him ? I am still looking for other trafos...A-24, HS-50....CJ said:probably from Andy in San Jose, CA.
