I would suggest rotating the LEDs...
Other than that: this should work.
Jan
Jan
FANTASTIC!I've built what I would like to call a DIY Audio Analyzer. Not just an Audio Interface Frontend, because I integrated an Audio Interface, PC + touch screen, preamps, attenuators, output amps, Power Amp and 4-channel DVM module into a single instrument. Integrating everything makes it a versatile and easy-to-use instrument. I'm still working on my website, but attached, you will find the chapters about this instrument that I already finished. I'm very happy with it, though it's far from perfect. The cabinet construction, made of wood, profile corner strips and steel plates, will not win a beauty contest. And the internals are a mess of wires and PCBs. Yet, it performs well, and with the modified UMC202HD I was able to get THD figures similar to a Babyface Pro FS costing 9 times as much.
What I'm happy with:
What could be improved:
- Having all functions integrated in a small form-factor instrument (30 x 30 x 35 cm).
- Very low THD.
- Sensitivity range of 2mV @ -3 dBfs up to 200V @ -3 dBFs.
- Protection range on the high-Z inputs estimated to work up to > 250V/50hz, even on the most sensitive 200mV range. (Admittedly, not tested...)
- Integrated DVM module, displaying the levels on all channels in V (RMS) and dBv. The DVM can also display gain/attenuation between any two signals.
I hope this build can be a source of inspiration, especially on how not to do it.
- Using relays for signal routing and stepped attenuators, instead of the clunky Aliexpress multi-deck rotary switches that I used. Cheap, but they are garbage. There is varying contact resistance, and you need a torque wrench to rotate the switches.
- Better cabinet construction.
- Lower noise outputs (thank you, Behringer for not including a decent LPF on the DAC output).
- Instead of Bourns multi-turn pots for level adjustment, use e.g. ALPS RK27 series pots with a Vernier reduction. I made one myself on the mic preamp gain potmeter, but there are better, commercially available Vernier reductions.
- Reduce the number of separate PCBAs to a minimum to minimize wire clutter, hum pickup etc. Place all front-panel switches, pots, connectors etc. on one or two PCBAs.
Jan
OOPS!I would suggest rotating the LEDs...
Replace the 0R with anything you want I guess...And instead of a direct connection betweensignal ground and chassis ground a 10 to 100R resistor to avoid ground loop currents. Many people shunt this resistor with a 100nF cap and anti-parallel diodes.
Jan
My reaction as well. There actually is a possibility of a resonance at diode switching but the issue is mostly of radiated RFI. The rectified DC is filtered...and filtered...and regulated...and filtered...so, no, not necessary. But also, no harm either.Replace the 0R with anything you want I guess...
Cap and diode shunt? really?
I guess I can add this as an option but are we real here?
All the rest!My blind spot is that I don't know what this thing is actually powering.
FANTASTIC!
Not really what I am after, but your build is magnificent!
I like those things! I like the will it takes to complete these projects!
My version (philosophy ? ) is a bit different than yours, but yes indeed, there are quite a few inspiring section that I will study!
Funny enough, I was searching the web for RMS converters and found exactly what you are using, the AD8436!
I was looking at the AD 736/737 (as used by Pete Millet) some discrete version (Heatkit AC volmeter and HP)... There are several options. It is a matter, at the current design stage I am, to chose a good viable and affordable alternative. So far, i Found that discrete AC/RMS converters are simple in theory and build, and inexpensive, but are really ******* to calibrate/adjust/tame! and are quite intolerant of temperature drift! To the point of given the quality and simplicity of those AD converters on a chip, at 10 to 30$ for the chip is actually worth every penny!
I have also to explore the THAT "audio engine" that are used to build dynamic processors, they all contains a RMS/DC converter that are quite capable and some include the op-amps etc needed. I have to dig on their site.
Maybe there is some misunderstanding, perhaps from my side? I was referring to R7 from the schematic, which I would propose to change to a 10...100R resistor, maybe shunted with a 100nF cap and antiparallel diodes. I did not refer to the filtering/reservoir caps or the C1...C4 parallel to D1...D4. Such a resistor is quite common in power amps, active speakers etc. See also the chapters Stepped Attenuator and Line-Input and Power Supplies and Grounding from the zip file in post #25 for your reference. This resistor is commonly found between the input ground connection and the chassis. The 100nF cap is supposed to tie the input cable shield to chassis ground for RF signals, for what it's worth: In the tens or hundreds of MHz region, the inductance of the capacitor leads will make it completely ineffective.My reaction as well. There actually is a possibility of a resonance at diode switching but the issue is mostly of radiated RFI. The rectified DC is filtered...and filtered...and regulated...and filtered...so, no, not necessary. But also, no harm either.
The output decoupling cap is 10X the recommended value.
Hello all
We had a very interesting discussion Here about what is available and how to chose software to use a sound card as the basis of an audio measuring system.
One thing that became obvious during the discussion is that for reason of practicality, some sort of hardware interface, or "front end", to the sound card. must be designed and built.
This is a very practical thing to have since usual good quality measuring instruments are costly and not necessarily toward audio measurements.
- We need isolation from the PC USB port, to prevent ground loop if any. (from KA Electronics.com)
- We need controlled attenuation so we can measure large signals input.
- We need a way to set repeatable reference signals
- We need to be able to drive large signals at very low impedance to test transformers and speakers (from Abey Road d'Enfer)
- We need proper known impedance in and out for meaningful test results and calculation
- We need protection and even isolation between the sound card and the front end interface. (from KA Electronics.com)
Considering the Sound Card (SC from now on) I have a few options.
USB Isolators are now common, but to test at 192kHz sample rate UAC2 is needed and High Speed (480M) isolators remain not so common or cheap. QA is isolated similar to the way I did on my Analyser.
Thor
It depends on what you consider "not so common or cheap".
When I made my own High-Speed USB Isolator based on the TI ISOUSB211 chip about two years ago, they were indeed quite expensive: over 300 Euros if I remember well. They can be had for 50 - 80 Euros or so nowadays.
Topping HS01 USB Isolator
iDefender+
and Hifime High-Speed USB Isolator V2.
If you can get the ISOUSB311 chip
I remember that thread and experiments on the Behringer on DIYAudioI've built what I would like to call a DIY Audio Analyzer.
Isolated Inputs and Outputs and I2S isolation might be better, but if one wants to use a stock USB Audio Interface and a relatively simple frontend, I guess a USB Isolator is still a good option to avoid ground loops.
At least it works for me.
I don't know which one is the better option.
Never mind, I found everything I need!I'm still here and right now I am breadboarding a 'sorta' DOA.
This thing will come dowwn looking like a Melcor "2520" op-amp.
I have found the pinout but not the part number for the pins on the op amp and on the receptacle pins for the mother board. Any one?
I have looked at Mouser and DigiKey and found a few things but I am not sure....
