Sontec EQ - Need help Troubleshooting High shelf switching
elskardio
Montreal - Canada
Hi guys,
I'm working on an EQ prototype based on the MEP250.
My High frequency band works perfectly in Bell mode but the moment I switch for High shelf I get a lot of hiss and oscillation... The IC are properly bypassed. I ran some simulations in LTspice and everything looks fine.
Any hint on what could be the cause?
Thanks for your help
I´m too lazy to search for the original schematic. But what I see is that your 5534 lacks the compensation cap. And IIRC R35 was much lower in later revisions of the 250.
Thanks jensenmann
Here's a link to the original schematic:
http://www.gyraf.dk/schematics/Sontec_MEP250a.GIF
I'll test with a 22pf compensation cap tonight. Also I will try with the Bias circuit disconnected to see if it changes anything.
SW-pin3 connects to the other side of R31 (only one half of the dual rev-log pot is shorted out, the 3k3 R31 remains in circuit) ...
Thanks Harpo! That was it
I must have checked the schematic a 100 times and never saw the mistake  ::)
Quick question...
Should I add the compensation cap to the filter's 5534 ? The original doesn't use it... I know it's essential to run stable at unity gain... but in this particular eq circuit?
IIRC additional compensation cap between pins 5/8 for the NE5534 shouldn't be needed.
You are aware, the boost/cut pot is missing the center tap connection ? (pot is at least a 4-pin device)
Thanks Harpo
Yes the Center tap is connected to ground. It was pretty hard to find the pots... luckily found some Bourns that works really well!
