Trying to design a "buffer" circuit that will allow a chosen reverb tank to be driven by any amp's drive/recovery circuit (ie. the big names: Fender, Marshall, Vox, Boogie, Orange, Peavey, etc). I really need this design to be passive if at all possible. If this isn't feasible/realistic I could use a 9v circuit if absolutely necessary.
I'm an amateur so please bear with me, but I'm thinking :
- Start with the most sensitive/easiest to drive tank.
- Use an input and output pot, or resistors selectable via rotary switch to attenuate the signals to/from the drive/recovery circuit as needed for each amp variety.
Obviously the main obstacle would be impedance mismatch, but as long as the signal never gets extremely anemic or extremely distorted I can live with a little extra noise from poor impedance matching. Watcha think? I don't have a shop right now, or a wide variety of amps to test. Would this work in a passive circuit without major problems? Again, I can live with a little noise, heat, inefficiency or even moderate signal degradation for some amp varieties as long as the overall SOUND is still acceptable.
Thanks fellas!!!
Thanks fellas!!!
