evil grill
Payment sent for 4 kits.
Looking forward to this project.
elskardio
Re: CA-250 EQ // 3 band Sontec in 500 series format
« Reply #181 on: March 09, 2020, 10:04:46 AM »
Thanks to everyone who placed an order. Your kits will ship by the end of the month.
You'll receive a private message with the tracking number of your package and the download link for the build guide.
evil grill
« Reply #182 on: April 06, 2020, 08:50:44 AM »
Hi!
I have'nt recieved a tracking number. Is there a delay?
elskardio
« Reply #183 on: April 06, 2020, 09:15:28 AM »
Hi!
Yes sorry about that... I just picked up my front panel shipment 2 days ago. It took an extra 10 days to reach Montreal  :-\
I will pack and ship the kits this week  ;)
Fuzz Face
« Reply #184 on: April 16, 2020, 04:27:42 PM »
Thanks for everything Gabriel, I am super excited for these!
Bobby Baird
« Reply #185 on: April 16, 2020, 06:20:36 PM »
Same appreciate you offering the kits.
Bobby Baird
« Reply #186 on: April 24, 2020, 05:16:29 PM »
I have built my pair, but at the unity gain calibration step. I have the trimmer maxed out, and I'm still 7db short on gain on both units. I checked all resistor values before populating. Any suggestions? Thanks in advance.
elskardio
« Reply #187 on: April 24, 2020, 07:31:50 PM »
Hi Bobby,
What’s your test setup? DAW with an audio interface? Are you feeding a balanced signal to the module’s input?
Bobby Baird
« Reply #188 on: April 24, 2020, 08:03:40 PM »
Hi Bobby,
Cubase 10, steinberg mr816x, balanced cables into Radial workhorse
Bobby Baird
« Reply #189 on: April 24, 2020, 09:25:07 PM »
Weird changed inputs and outputs on interface. Unity gain works now.  ::)
Bobby Baird
« Reply #190 on: April 24, 2020, 10:40:12 PM »
Racked calibrated. Thank you!
« Last Edit: April 24, 2020, 10:57:05 PM by Bobby Baird »
elskardio
« Reply #191 on: April 25, 2020, 12:36:11 AM »
Enjoy  ;)
Bobby Baird
« Reply #192 on: April 25, 2020, 01:19:52 AM »
So... one of the CA-250's high band is not functioning correct. While injecting pink noise using span spectroanalyzer set to 1 octave smoothing to visualize curves. I have the high band shape set to sharp. Frequancy knob set all the way ccw. Gain 12, and the lowest it will go is like 7.68k on span where the knob says 2khz ccw. My other CA-250 works flawlessly. I built both at the same time using the same bom supplied last week. I made sure to take my time. As, I have no schematic. I'm not sure were to start troubleshooting this part of the circuit. Hope to fix this bug. I did bump c28 with solder iron by accident, but it seems cosmetic, and I'm sure that's part of the low band.
« Last Edit: April 25, 2020, 01:25:51 AM by Bobby Baird »
elskardio
« Reply #193 on: April 25, 2020, 02:53:29 PM »
Hi Robert, please check your personal emails. Thanks
critterkllr
« Reply #194 on: May 07, 2020, 10:04:11 AM »
I just built a pair of these EQ’s and they are fantastic! The quality of everything is really good.  The way you fit all of the pots in this EQ was really clever. I’m really grateful that you decided to sell them for us to DIY.
The sound is top notch. Any boosts or cuts sound really natural. No weird phasey issues boosting high. It sounds like that’s the way I tracked it.
The only feedback that I have would be to specify that the standoffs are two different sizes. Like a dummy, I didn’t realize until I was over halfway through soldering the main connector. I used a short standoff on on the switch. Oops! Everything else was really professional and thorough. This was a nice easy project!
evil grill
« Reply #195 on: May 07, 2020, 10:21:05 AM »
Mine are still somewhere between Canada and Sweden.  Really annoying as I was planning to use them on a recording end of May.  :(
elskardio
« Reply #196 on: May 07, 2020, 11:49:58 AM »
This is clearly specified in the build guide.
Unfortunately I don't have any control over the postal service...
critterkllr
« Reply #197 on: May 07, 2020, 03:17:08 PM »
Okay, dude. Just trying to help. My feedback is to add a note:
 “28. Solder the 6-pin header and install the 11mm standoff. *verify you are not using a 9mm standoff*
« Last Edit: May 07, 2020, 03:34:32 PM by critterkllr »
Fuzz Face
« Reply #198 on: May 07, 2020, 08:41:56 PM »
I went with some aluminum knobs, whaddaya think?
evil grill
« Reply #199 on: May 10, 2020, 11:27:08 AM »
Anyone tried tle2071 instead of TL071?
Last post December 01, 2019, 11:57:41 AM
by kante1603
Last post March 10, 2018, 11:13:39 AM
by elskardio
Last post June 16, 2018, 11:52:02 AM
by mysticmerlin
Last post December 02, 2019, 08:15:48 PM
by fazeka
