CA-250 EQ // 3 band Sontec in 500 series format
This looks great! Well done.
Any chance of getting partial kits without the front panel? I would like to build a +-6db pair.
Nikos
living sounds said:
What about the center tapped pots, though? I don't think those can be bought at mouser....
Yes they can  ;)
http://www.mouser.com/ProductDetail/Bourns/PTT111-3217A-B503/?qs=sGAEpiMZZMtC25l1F4XBU1gRILB9VStL6OifK3MMtjE=
Vac11 said:
There are few trimmer resistors on the PCB... What are they used for?
There's a Bias adjustment for the NE5534 on each band. Near the Input/Summing section, there's another trimmer to cancel the noise on the Bypass switch and another one to adjust the output level of the EQ.
The calibration is pretty easy. There's Test points on the pcb. All you need is a Digital Multimeter.
